-   -   Field charging (https://www.rctech.net/forum/radio-electronics/1075260-field-charging.html)
EvilR2.0 11-03-2020 02:51 PM
Field charging
Lipo as charger power source?!
Use the 406duo at home off a 24v supply but I need something for field charging, I have the ISDT Q8 and was looking to power it off a Lipo, after input on cell count and mah size.
I mainly charge 2S 360mah and 4S 1400mah
Solico 11-03-2020 03:06 PM
I
I wouldn't know if you can use a LIPO as a power source, but I would assume you can since I know that some drone hobbyists will charge a massive pack and then use it to charger the drone's smaller packs out on the field.
I'm nearly sure you can use motorcycle batteries though, like ATV batteries.
Roelof 11-03-2020 03:12 PM
Go to the scrapyard and get a small used car battery
billdelong 11-04-2020 05:43 AM
Yes I have used a larger 6S pack as a supply line input to a charger to charge smaller 2S packs at the beach... very important to set the LVC on the charger input so you don't kill your supply battery!
the rc guy 11-04-2020 06:16 AM
this will all depend on how much weight do you wanna carry?. I used a small 12v rechargeable battery for more than 3 years till I dropped it(end of that it was 12 pounds) it would charge up to 14.4 volts...not sure of exact mah. but I could get 6 charges outa it putting 2100mah back in a 2 cell lipo...it was a lawn tractor battery I purchased thru amazon..it was like 24$ usd..
riceball777 11-04-2020 10:22 AM
You can get an 8,000-10,000mah 6s lipo to power the charger
something like this
https://www.smc-racing.com/index.php...product_id=590
or you can hook up the charger to your 12volt car battery.
Solico 11-04-2020 12:20 PM
Could a mini generator allow for more amps/bolts and just run off gas to keep charging? I wonder what the ratio would be
EvilR2.0 11-06-2020 10:15 AM
Thanks guys
Idea is to be portable and when I go racing 1/28’s id rather not take my PS and charger etc so has thought as the Lipos I use are 2S 360mah I could take a decent size 4-6S and just charge them at my work table.
For my other use the smallish car battery would be a good idea, gutted as I had an awesome car audio dry cell battery I had from my competition car audio days I gave away a year or so back 🤦🏻‍♂️
