Like Tree1Likes
  • 1 Post By papagogo
Discharge Bank Temp
Old 01-22-2020, 11:34 PM
Di_spencer's Avatar
Trader Rating: 18 (100%+)
Default Discharge Bank Temp
What kind if temps are you guy's getting from your 40a discharge banks? I am testing one I made myself and I want to see if I did a good enough job with cooling. Thanks
Di_spencer is offline
Old 01-23-2020, 01:07 AM
Roelof's Avatar
Just look up the specifications of the resistors, they are mentioned in the datasheets. Probably with easy they can withstand 150 degrees celcius.
Roelof is offline
Old 01-23-2020, 02:13 AM
Di_spencer's Avatar
That was my thought as well but the datasheet doesn't seem to exist for the ones I have. I found similar rates with max at 200C so I'll check what mine gets to but I don't think it's that high. I'm just try to get an idea of what the commercial ones are like.
Old 01-23-2020, 07:35 AM
sacmiata's Avatar
Trader Rating: 27 (100%+)
Mine that I have been using for about 3 weeks is just those cheap amazon 1 ohm 100 watt resisters. I don’t think there are specs on that either and I have one fan on top and a heat sink and fan on the bottom. I am just under 120 c over most points I was able to read. Mine is built for 25 amp but it should be the same load per resister as a 40amp as I would just be adding resisters to get to that point. Probably have 15 cycles through it and it’s doing fine.
sacmiata is offline
Old 01-23-2020, 08:18 AM
the rc guy's Avatar
with a little finger work by user you can find spec sheet thru manufacture and parts #...
the rc guy is offline
Old 01-23-2020, 10:09 AM
Around 175 degres celcius !
At 8mn00
billdelong likes this.
papagogo is offline
