Which brand model HALL sensors are used? >
Old 01-13-2020, 04:58 AM
Roelof's Avatar
Default Which brand model HALL sensors are used?
I have a small theory I want to test but the specifications of these sensors are very wide. I wat to know what the output current of these sensors may be so I can test some things.
Al I know is that most of the Hall sensors listed on farnell are able to work with 10mA up to 25mA. From an old motor I have the P29Xf SMD code in a SOT23 housing but no luck to find something about this one.
Roelof is offline
Old 01-13-2020, 07:14 AM
burito's Avatar
Have a look at the Melexis website...
burito is offline
Old 01-13-2020, 10:32 AM
Roelof's Avatar
I just want to know which model is used by Hobbywing, Muchmore and others so I can look up the specs. I do no where to buy sensors or how to choose the right one. Problem is that codes on thes small SMD housings do not show information in the large SMD code book.
Roelof is offline
Old 01-14-2020, 04:02 AM
burito's Avatar
Ok, I see.
One of the sensors, which in the past was in use by various suppliers, is the Melexis US2881. I don't know what is used these days.
Back when I was at LRP, we obviously tested with quite a few different sensors and I can tell you that they do not make much of a difference. When compatible sensors are compared of course!
burito is offline
Old 01-14-2020, 04:42 AM
Roelof's Avatar
OK thanks, regarding the specs it is one that is safe for my test.
Roelof is offline
