Trackstar 80a esc problem >
Old 01-11-2020, 02:00 PM
Default Trackstar 80a esc problem
I have a trackstar 80a esc that when turned on all three lights flash
the only way to stop them is to turnn the esc off
anyone have a solution to this
skipdg is offline
Old 01-12-2020, 05:37 AM
Trader Rating: 31 (97%+)
Is this a brand new ESC? Chances are you just need to calibrate it. If it's an older ESC I would attempt to re-calibrate it and if that doesn't work then I would consider replacing it with a different brand of ESC. I haven't had much luck with any of dozen or so budget brands of ESC's that I have used in the past, most do well for about 6 months or so, then give up the ghost after too many hard impacts
billdelong is offline
Old 01-12-2020, 05:40 AM
SteveM's Avatar
Trader Rating: 156 (100%+)
How to program the Turnigy Trackstar 80A Turbo Sensored Brushless ESC
● Hold the set button and switch on the ESC
● Solid Yellow LED indicates ready to calibrate NEUTRAL
● Leave throttle neutral, press SET, yellow LED flashes while reading NEUTRAL
● Solid Orange LED indicates ready to calibrate Full Throttle
● With throttle to full, press SET and the Orange LED will flash while calibrating
● Solid Red LED indicates the ESC is ready to calibrate reverse
● With throttle in full reverse, press SET and the Red LED will flash while calibrating
● When the ESC is done calibrating full reverse it will flash all three LEDs in sequence to indicate programming is done.
SteveM is online now
Old 01-12-2020, 06:07 PM
When you turn it on all three lites flash
when you press the cal button and turn the esc on all three lites flash
skipdg is offline
Old 01-13-2020, 09:27 AM
Trader Rating: 24 (100%+)
If it is the turbo model it is sensored only, make sure sensor cable and sensored motor are both good.
chadp is offline
