Orion Touch Duo Internal Power Supply >
Old 12-02-2019, 12:51 PM
Vegas456's Avatar
Default Orion Touch Duo Internal Power Supply
My Orion Touch Duo charger does not work using the internal power supply anymore, but it does work when plugged into an external power supply? Has anyone else had this issue and is there any way I can fix it? Thanks!
Vegas456 is online now
Old 12-02-2019, 09:48 PM
GerryH's Avatar
Trader Rating: 24 (100%+)
The internal power supply is most likely dead. On some AC chargers, it's pretty easy to replace because it's just a laptop/LED style power adapter mounted inside.
Think the Orion charger does not use this style. And I think this might be a challenge for you since you'll need a 200w power supply.
I fixed someone else's AC charger (60w) by finding a laptop style power supply and removing it from it's case and mounting it where the original was. Then cut the output cable short and soldered to the charger internally. If I remember, the only thing I had to do was to enlarge the AC plug hole slightly.
GerryH is offline
