Small Futaba compatible receiver
Hi,
are there any small receivers that are compatible with Futaba 3pv (I´m using a R203GF-reveiver now)? There are some on ebay and banggood, but which ones will work? |
There are some micro FHSS receivers for 1/24 and smaller scales, they also have snaller connectors for the servo/esc.
https://nl.banggood.com/DasMikro-FUT...SABEgIg6_D_BwE |
You can run the R204gfe-e. It’s a good amount smaller than your r 203gf.
Not really, its about the same footprint.
Originally Posted by Roelof
(Post 15549906)
https://nl.banggood.com/DasMikro-FUTABA-S-FHSS-Compatibe-Micro-4-Channel-Surface-Receiver-Board-For-Micro-Racing-Cars-p-1312887.html?gmcCountry=NL¤cy=EUR&cur_wareho use=CN&createTmp=1&utm_source=googleshopping&utm_m edium=cpc_bgs&utm_content=frank&utm_campaign=frank-ssc-nl-all-19bf-1122-v2&ad_id=394361131390&gclid=EAIaIQobChMI1JDy97z95Q IV0uR3Ch3wnQxDEAQYBSABEgIg6_D_BwE |
(Post 15549906)
Originally Posted by billdelong
(Post 15550580)
DasMikro branded Rx's are legit, I have not used them for Futaba, but I have used them for both KO Propo and Sanwa radios flawlessly, they produce slightly slower frame rates because they use lower quality components (roughly 15ms using my PCM tool), but the slowness is undetectable and did not degrade my fast lap time nor consistency.
What kind of case do you use to that receiver? |
Originally Posted by D1360
(Post 15551481)
Thats interesting, but it uses JST(?) connectors? Do you use a adapter on those connectors?
On my search for small receivers, I came across the FRSky. Haven't tried it yet myself, but I heard good things about it. There are some models compatible with futaba, for example the TFR4B. Very small, seen it on some electronic setups pictures at Petit RC.
https://www.frsky-rc.com/product/tfr4b/ |
| All times are GMT -7. It is currently 11:51 PM. |
