Hobbywing program box vs WiFi express
I have a hobbywing xr10 pro 160a esc g2 with the program box. I just want to know if that is any Benefit of having the WiFi express vs the program box. Is there anything the WiFi express can do that the program box can’t? |
I think the wifi express logs multiple entries for temperature/rpm data, and it also allows you to save/load multiple profiles with single (or multiple) ESC/s.
I'd wait to hear others' responses though - while I've used both and have the app, I haven't bought my own express yet (just borrowed friend's). The app is very nice, Hobbywing has nicer/neater software than Tekin, also seems bug-free. Works well on iPhone too. If you already have the program box I don't think there's any huge functional benefit, it's just very neat and convenient. The app has a demo mode (for each HW ESC) so if you like, you can install it on your phone and have a play around before buying anything. |
You can download the HW app to your phone and do a direct comparison before buying the WiFi module.
The biggest thing was that the wifi express can update ESC firmware from your phone. You can also leave it in the car and tune without having to get off the driver's stand and pulling the body off, if you really wanted.
The biggest annoyance, however, is that it sometimes takes up to 5 minutes to connect to my phone which is really annoying if you're trying to really tune something in. |
Originally Posted by anthonyscardina
(Post 15546982)
I have never used the HW programming box. I love the WiFi Express Module. Easy programming from my phone with the free app. I bought it for 40ish bucks at my LHS.
I need help with firmware. I updated the program box to the current PB-4.0.01. But When I plug my Quicrun10BL120 esc into the box it tells me to upgrade the firmware? I have checked Hobbywings site and there is nothing for this esc.
Originally Posted by TonyD.
(Post 15549512)
The thread above is the Hobbywing support thread. You’ll probably have the best luck reading the thread and then asking your question if the answer isn’t already there. :) :) |
Thank you. The program box I was sold doesn't work with Quicrun line of esc's. I need to but the led box. Wish the sales guys was more informed when I bought it.
quic runs can be tuned using the set button. Whilst not as easy as the program box, it's a pretty convenient feature that I wish the XERUNS had.
QUESTION: Now, in 2021, Is the Hobbywing OTA (over-the-air) programmer the current/modern replacement for the Wifi Express?
Hobbywing's website (with a lot being lost in translation, I think...) says that some XERUN ESCs are compatible with the OTA programmer. I have the XR8 SCT, and the webpage for said ESC says it's compatible with the Wifi Express module, but it appears that product isn't made anymore? Basically, the OTA programmer is Bluetooth only, or does it support Wifi AND Bluetooth connections? LOL, what the hell programmer can I use?!? |
Use the OTA. The OTA and WiFi are interchangeable. The OTA is just easier for some people to figure out.
Originally Posted by Bsthetech
(Post 15814340)
Like, HW could have employed an "enter programming mode via the on/off button, then push the number of times to activate the preset options, with a beeping of the option number to confirm as set. Well, I guess that's how they get ya! |
Originally Posted by Ackchyually
(Post 15814352)
Thanks. I will check it out for sure. Seems like an easy option that's only a bit more $$$ compared to the LCD box. And just to confirm, there is no other way to program the ESC except for the programmers, correct? The manual lists several OPTIONS in a table, and the only way to obtain said options, other being stuck with Option #1 (default), is to program via a programmer, correct?
(Post 15814355)
...Just buy the OTA and be done with it.
| All times are GMT -7. It is currently 06:46 PM. |
