Gorilla tape softcase lipo for bashing. Leave open rear for vent OK ? >
Like Tree1Likes
  • 1 Post By Billy Kelly
Old 10-09-2019, 09:47 AM
HardBash's Avatar
Default Gorilla tape softcase lipo for bashing. Leave open rear for vent OK ?
Hello
i have alot softpacks
if i want reinforce them.
Can i put gorilla tape round them softly ( not tight )
And leave the rear end open for venting is enough maybe ?
I was thinking about protect them extra in front and sides , if i crash in bushes with hard sticks or so that maybe can penetrate the softbodies too easy if they got under the body shell also in fast crashes
Let the whole rear end vent is more than hardcases can do i think also ?
Many of my favorite big lipos like 7000mah that are good and cheap is softcases
so gorilla tape some `? is this ok?
HardBash is offline
Old 10-09-2019, 10:25 AM
Billy Kelly's Avatar
I use electrical tape or gorilla tape on more then a few batteries.
Billy Kelly is offline
Old 10-09-2019, 12:13 PM
HardBash's Avatar
OKEY
is this dangerous or okey ?
HardBash is offline
Old 10-09-2019, 12:28 PM
Originally Posted by HardBash View Post
OKEY
Never thought about it. Some of mine have been taped for 5-6 years.
HardBash likes this.
Old 10-10-2019, 02:55 AM
HardBash's Avatar
OK
sounds like no problems them
I will try two layers gorilla tape, i leave the rear end open for venting
And not tape too tight is important also i think.
THANK
you Billy Kelly
HardBash is offline
Old 10-10-2019, 03:34 AM
HardBash's Avatar
this maybe is the best way
also see the specs of the different packs still easy ?
1m Transparent Lipo Battery Casing PVC Heatshrinkable Tube Model Accessories Battery Case
https://www.banggood.com/1m-Transpar...r_warehouse=CN
cheap, different sizes, free shipping
You must be carefull when heat them, i will do it outside.very carefully
i will be back whit more info about this , need try first couple weeks
HardBash is offline
Old 10-10-2019, 06:49 AM
Trader Rating: 31 (97%+)
I probably wouldn't want to add any extra wrap around the packs, this may restrict the flow of air and trap heat in the pack as it discharges.
I have used velcro straps for many years with soft lipo packs without any issues, though I have found the TEKNO style battery tray to work the best for me, with an extra vertical strap that runs lengthwise to prevent a pack from sliding out of the tray. I have used TEKNO straps on other brands of cars too, simply used a dremel to cut a couple notches at each end of the tray to fit the new vertical strap in place.
billdelong is offline
Old 10-12-2019, 06:06 PM
uDi_MP7.5's Avatar
I've reinforced soft packs with tape no problems.
Most tape has some stretch so wrapping all around (not too tight) is fine in my experience.
I also put some tape on new packs just around the base where they contact the battery tray, to prevent damage to the original soft case heatshrink.
uDi_MP7.5 is offline
