Which ESC has the strongest brakes for on road? >
Like Tree2Likes
Old 08-12-2019, 11:55 PM
Trader Rating: 39 (100%+)
Default Which ESC has the strongest brakes for on road?
I'm all Hobbywing xr10 ... but sometimes the brakes are not strong enough when it comes to braking late in corners.
Phillip F is offline
Old 08-13-2019, 03:53 AM
Is it for stock or mod? XR10 would be one of the strongest. Can also try lowering brake frequency, or you can add some anti dive, stiffer front springs, thicker front shock oil, shim out the top of the front shocks
Hasselhoff is offline
Old 08-13-2019, 08:48 AM
PRO PERFORMANCE RC XSC150P features 28 adjustable parameters that is quick and simple to adjust with a separate program device. Stock and mod firmware is included to maximize the performance of both. I was personally running Xr10proís before I tested the prototypes and on high bite with the Xr10pro had my brake strength at 100 on the esc and epa max on the radio and not enough brakes. I have yet to go over 85 percent brake strength on the XSC150P
Phillip F likes this.
brian mills is offline
Old 08-13-2019, 05:47 PM
not looking to flame you but is this true? If you apply brakes at 100% the transistor on versus off time is the same whether its high frequency or low frequency. Low frequency means the transistor is on much longer and off much longer. High frequency means the same just more on and off in a given period of time. The efficiency of a transistor goes down as the frequency gets higher resulting in more heat in the transistor. So if your trying to dissipate regenerated power from a motor in deceleration an inefficient transistor may be better at stopping the motor.
like I said I dont want to argue im just curious where that comes from and im open to being wrong.
gigaplex likes this.
Bry195 is offline
Old 08-13-2019, 09:12 PM
rcbuggy88's Avatar
not really an answer but who actually needs 100% brakes. Is it like a really tight track or something? Maybe just brake sooner? What do the people at your track who are fast think? I've never had a problem with brakes but then again I'm not the most experienced. Just wanna know why.
rcbuggy88 is offline
Old 08-13-2019, 09:40 PM
I race with a XR10 brake frequency is 1K at 100% still not enough to slow down and brake late from a high speed straight to 180 and 90 deg corners to be faster. .... this is racing ON ROAD.
Old 08-14-2019, 12:50 AM
gigaplex's Avatar
The Hobbywing ESCs are great, but are not known for their brake strength. Most people I've talked to suggest LRP brakes are much stronger.
gigaplex is offline
Old 08-14-2019, 02:27 AM
DirkW's Avatar
Straight from the manual I guess:
"3F. Brake Frequency
The brake force will be larger if the frequency is low; you will get a smoother brake force when the value is higher"
@OP: Have you checked this setting (quoting the manual again)?
"3G. Brake Control
Option 1: Linear Hobbywing has recommended using this mode under all circumstances. The braking effect is a bit weaker in this mode than in Traditional brake mode, but it’s easy to control and brings great control feel.
Option 2: Traditional This brake mode is the same as to the XERUN series of ESCs, the brake force is stronger.
Option 3: Hybrid The ESC switches the brake mode between Linear and Traditional as per the vehicle speed to prevent the slide (between tires and track) from affecting the braking effect.
Note 6: Please select the right mode for your vehicle as per the track condition, motor performance, and etc"
Don't know how much effect this setting has, but maybe worth a try?
DirkW is offline
Old 08-14-2019, 04:00 PM
"3G. Brake Control
Option 1: Linear Hobbywing has recommended using this mode under all circumstances. The braking effect is a bit weaker in this mode than in Traditional brake mode, but itís easy to control and brings great control feel.
its pretty clear in those directions for sure and you have to go with what they describe.
However, brakes and throttle are a duty cycle at the esc. 10% throttle equals 10% on versus 90% off. 40% throttle is 40% transistor on versus 60% transistor off. The switching frequency of the transistor is fixed at say 1k or 4K by setting and the duty cycle is normally an on versus off time. Its kind of the definition of pulse width modulation.
Bry195 is offline
Old 08-14-2019, 05:13 PM
the rc guy's Avatar
in all my many years of brushless esc use. I have found that the Quark MK3 has the best and strongest brakes and with the card you can put 150% brakes on esc..but its old and discontinued now.I have all the Quark esc.they were made in south korea in the day
the rc guy is offline
Old 08-15-2019, 03:39 AM
yup i race on road also. To get more from your brakes you can try adjust the settings i suggested, even thicker shock oil helps, i personally use the Tekin rs pro black edition which has the strongest brakes ive used. Ive had the xr10 before and it had good brakes for me
Old 08-15-2019, 03:41 AM
Ive used both and the brakes were quite similar, also depends on whether your racing mod or stock, FDR plays a role, car setup, i personally use the Tekin rs pro black edition and the brakes are ridiculously strong.
Old 08-15-2019, 03:44 AM
like the other guy said i was literally just quoting the manual haha personally never REALLY saw a difference in frequency change.. but setup plays a big part also
Old 08-15-2019, 04:17 PM
R/C Tech Elite Member
JayL's Avatar
1. Are you totally sure you are not locking up and thinking the brakes are weak since you are sliding? the strongest brake still has a traction limit max to slow you.
2. It makes no sense but I always get stronger brakes when I ran HW by setting reverse to 100%, no I'm not running reverse but it seems to help the brakes for HW
JayL is offline
Old 08-15-2019, 11:18 PM
I'll try this. thx.
