How would you repair this broken wire? >
Like Tree8Likes
  • 1 Post By st_dragn_wagen
  • 1 Post By Dave_S
  • 1 Post By the rc guy
  • 1 Post By Juglenaut
  • 2 Post By Sir 51D3WAYS
  • 1 Post By m3rcfh
  • 1 Post By GuyIsDamGood
Old 07-04-2019, 02:55 PM
Dave_S's Avatar
Default How would you repair this broken wire?
I'm thinking of just using solder to spice in a smidge of wire and put heat shrink over whole area. (Using caution not to expose other wires in cable)
any suggestions of better way to fix?
Dave_S is offline
Old 07-04-2019, 03:04 PM
st_dragn_wagen's Avatar
can you get away with shortening the wire to where the break is? cut it at the break, and solder directly to the board, thus shortening the wire.
in all honesty though, and iv actually done this, if it's still working, just shrink tube over the damage and forget about it
Dave_S likes this.
st_dragn_wagen is offline
Old 07-04-2019, 03:30 PM
Dave_S's Avatar
That was original plan, but I was hoping for something prettier
II was going to wait to fix, but I suddenly felt motivated.
ended up just separating the black wire from cable to repair. I guess I'll just put wire sleeve on this cable after the heat shrink.
also this repair probably would have gotten me thrown out of soldering school.
Juglenaut likes this.
Dave_S is offline
Old 07-04-2019, 03:57 PM
the rc guy's Avatar
I would have added a short piece of blk wire with heat shrink and soldered it not have it so tight.
Dave_S likes this.
the rc guy is offline
Old 07-04-2019, 04:46 PM
On my rc car I took the pins out of the connectors, separated the wires, and made the cable into a twisted set, then put the whole thing into heavy duty heat shrink tubing. I thought about putting a ferrite choke on it.
Dave_S likes this.
Juglenaut is offline
Old 07-05-2019, 02:46 PM
Sir 51D3WAYS's Avatar
Cut all 3 wires, splice with solder. Or crimp new connectors, effectively shortening it and lengthening it as necessary with servo lead extenders.
mushroomed and Dave_S like this.
Sir 51D3WAYS is offline
Old 07-11-2019, 04:41 PM
Maybe just a drop of solder and shrink tube over it? Seems like it's not completely separated yet
Dave_S likes this.
m3rcfh is offline
Old 07-11-2019, 05:24 PM
Trader Rating: 264 (100%+)
Having to use extenders just leads to more connection issues. Can't understand why guys are so "happy" to cut/hack stock wiring. (Unless your entering a concoures event)
Andy Koback is offline
Old 07-11-2019, 09:36 PM
redmonster27's Avatar
Trader Rating: 32 (100%+)
redmonster27 is offline
Old 07-12-2019, 11:14 AM
I respectfully disagree. Personally, I have not had any issues with it, and I understand the plane guys do it all the time. Besides, the layout of my car virtually mandates a very long receiver lead from the esc, so an extender is a must.
Old 07-12-2019, 12:22 PM
Dave_S's Avatar
I use extenders, but prefer not too. I used to make my own cables to whatever length I want and just solder them to the circuit board, but these days pretty much all my electronics are in potting compound. I don't want to hack into that.
Dave_S is offline
Old 08-04-2019, 05:20 AM
I use this fix
-strip a small amount of wire from both ends of the Black-wire
-cover/shield the small amount of Red and White wire (to keep the solder off the wires)
-use Solder to join/fill the wire - gap
-remove the cover/shield on the RED and White wires
-then cover the Black-wire with black tape
Dave_S likes this.
GuyIsDamGood is offline
Old 08-04-2019, 04:43 PM
platgof's Avatar
I would just solder it and shrink the whole thing. Flux does a good job.
platgof is offline
