4s charger and connector questions
I was wondering what you guys are using to charge 4s batteries at a decent rate. i currently have an icharger 308 but have been thinking of down sizing. problem is finding a decent charger that can do 10-12 amps on 4s (yes i understand watts to amps calculations, just wanna know what ya'll are using). Also, i have been looking at connectors cause my deans just arent cutting it anymore in my 1/8th scale stuff. i really dont want to do EC5 and have been looking at xt60 but not sure if they are enough seeing as my deans arent enough anymore. I dont want to run the massive xt90 if i can get away with it.
R/C Tech Elite Member
Use real Deans connectors... not the cheap copies....
I use the XT60 on my 1/10 truggy and my short course....
Had an issue last weekend in my short course, truck died halfway thru a race... turns out the male ends on the XT60 were not making good contact. I had to use a small screw driver and spread them and it corrected the problem. You would not notice this due to the plugs snapping together so you assume you have a tight connection....
New male plug installed now
i use the xt90. I see peaks over 140 while in use which doesnt make the 90 imperitive but it might in a couple years and i dont want to change again as tech develops.
You need about 200 watts of power to charge a 4s battery at 12 amps. I use xt90 connectors and a skyrc d400 charger. It has a internal power supple so I use it on ac mode and it has 400watts max power at max of 20 amps charge rate. so I can changes my 4s batteries at up to 20 amps no problem.
I use an ISDT q6 for field charging. For connectors xt60's are fine for 1/8 if we're talking racing. Amp draw should be relatively low.
I switch all my 4 cells over to Xt 90 a few years ago. and have not had any issues ever. xt 60 wont cut it ..
