Like Tree1Likes
  • 1 Post By stevephone101
Sanwa PGS XB
Old 06-22-2019, 01:05 PM
Default Sanwa PGS XB
Hello,
i know that is possible to programm the PGS XB servo.
But can i also use it out of box without programming ?
I mean is it possible to race with it without programming ?
Would be finde to get some information.
ddick is offline
Old 06-22-2019, 07:47 PM
choisan's Avatar
yes, you can. it just performs like a normal servo with the fastest response if you are using m17
choisan is offline
Old 07-08-2019, 09:43 PM
stevephone101's Avatar
hi guys i just got a PGS-CX servo and the multi setting gear box a MT-44 radio and a RX-472 Receiver what i want to know is after i program the settings i want using the box
to use the programmed settings do i have to plug the servo into and leave it in the SSL port of the receiver or i can just plug it into the CH 1 or CH 2 port on the
receiver and use for steering or throttle thank you
stevephone101 is offline
Old 07-08-2019, 10:54 PM
choisan's Avatar
if you programmed the servo by the setting card, you can just use it at the ch1 & 2. i did the same.
choisan is offline
Old 07-14-2019, 08:44 PM
thanks man
choisan likes this.
Old 07-14-2019, 10:03 PM
choisan's Avatar
remember, if you use the program card to set, you can set 3 more last options where SSL you couldn't in the tx
choisan is offline
Old 07-16-2019, 09:09 PM
ok cool what settings do you use on your servo
Old 07-17-2019, 07:52 PM
Probably the most useful are the initial, mid, and end settings. I forget what the exact name is but they essentially work like a gain setting.
so what that means is you can make the initial, mid, and end response soggy or very hot and responsive. I set my chassis to be very responsive so for example the initial...I set it at the max setting that makes the wheels oscillate when I lift the car off the ground but the wheels or stable on the ground. This means that the at low angles it will be as responsive as it can be without losing control.
to do the same with mid and end i run the chassis on medium and tight corners and watch to see if the tires oscillate. I start with a low setting until the mid and end gets very responsive then push the setting up until oscillation and then back the setting off 10 percent.
Bry195 is offline
