Traxxas VXL esc and 17.5 motor? >
Like Tree3Likes
  • 1 Post By bob.less
  • 1 Post By killer rock
  • 1 Post By RC*PHREAK
Old 06-02-2019, 04:33 AM
DennyP's Avatar
Default Traxxas VXL esc and 17.5 motor?
Hey guys just curious, will the stock Traxxas VXL brushless speed control handle a basic 17.5 motor for 17.5 racing? Thanks
DennyP is offline
Old 06-02-2019, 05:13 AM
yes. It can also run as a sensored ESC,
DennyP likes this.
bob.less is offline
Old 06-02-2019, 06:14 PM
I'm sorry, but the VXL ESC is sensorless only. It can't run sensored.
MaX-D is offline
Old 06-02-2019, 08:14 PM
Location: northern Indiana southern Michigan all depends on the day.
i believe he was referring to the motor not the speed controller.
im a bit curious is the 17.5 motor so you can step in to a stock class?
if so you may want to look at at swaping out the speed controller too, most 17.5 stock classes are locked spec classes. meaning that they a just timing off end bell only. something that the vxl can't do, id look a something like a hobbywing juststock, tekin make a good couple offering too.
if its not a lock spec class an a mod class kindly let me reinsert my foot in my mouth
DennyP likes this.
killer rock is offline
Old 06-02-2019, 09:16 PM
RC*PHREAK's Avatar
Trader Rating: 132 (100%+)
I'm sorry. you're wrong.
bob.less likes this.
RC*PHREAK is offline
Old 06-03-2019, 05:12 PM
My bad, I misunderstood.
MaX-D is offline
Old 06-04-2019, 04:45 PM
If you look at your ESC youll see that it has a sensor port.......
bob.less is offline
Old 06-05-2019, 03:24 PM
This may not be true Traxxas like to do rolling updates with out changing the sale code. He may have a earlier version with out a sensor port. Just like there's a 2pole and a 4pole velineon motor. Both are 3500kva and 3s compatible. Newer one are 4pole older one are 2pole. Just because of the number of different versions of vxl-3s out there it safer to assume that's there a none sensor version.
Old 06-06-2019, 08:40 AM
I know that I have 2 of them (early versions ) and both have sensor ports.......
bob.less is offline
Old 06-06-2019, 08:11 PM
ok i tripped over a form that could accurately distinguish between the two vxl-3 esc the 3355x earlier ver. and the 3355r current version(i think, don't know. don't care enof). while trying to find a pic with will w and w/o sensor port. it does show the earlier one with the sensor port not the later one. so i will eat my foot on those two facts.
the issues i had with the post,
If you look at your ESC you'll see that it has a sensor port.......
that i was trying to point out. that WE doen't know the ver. of vxl-3 that he has. telling him that vxl-3 has a sensor port when the version 3355r doesn't. so unless you got insider information on his particular esc. thats were my issues lie
Old 06-07-2019, 02:32 AM
t
bob.less is offline
Old 06-13-2019, 09:22 PM
DennyP's Avatar
Itís actually the VXL 3S which can run sensored, sensorless and brushed motor set ups. So I just need to find out if the 17.5 SCT class thatís running locally is running a sensored or sensoredless setup. Then I need to decide WHICH 17.5 to run..🤦🏻*♂️🤷🏻*♂️
Thanks for all the input guys!
DennyP is offline
