-   -   LRP Flow X does not turn on (https://www.rctech.net/forum/radio-electronics/1043992-lrp-flow-x-does-not-turn.html)
Sir 51D3WAYS 05-29-2019 09:20 PM
As per title, I bought one brand new. Doesn't turn on. TC spec if it matters. I'm not sure if I want to start ripping into it or send back to the hobbyshop.....
I know I can cut off the switch, but don't really want to do that incase it is something else. That would make returning it more complicated....
Scrubb 05-30-2019 08:54 AM
Pull the switch out off the switch casing to make sure the switch wire did not break off and is making a constant connection. The speed control is “on”. When the switch wires are disconnected.
malkiy 05-30-2019 09:31 AM
I wouldn't mess with it, especially if the ESC is only a few days old. LRPs warranty system is suspect. Not sure what it's like now with new ownership. Swap it out for another or get your money back.
Andy Koback 05-30-2019 10:02 AM
Return for exchange. Hobby shop can test/verify themselves. Once you open it up, warranty is void!!!
Sir 51D3WAYS 06-02-2019 02:36 AM
Problem solved. Dodgy female deans plug on the battery lead.:sweat: Soldered in a new one.
Embarrassingly, I had to take my car/setup to the LHS to solve the problem..... dude there wiggled the power leads and it magically worked.......:blush:
