Cheap servos and Spektrum receivers >
Old 05-28-2019, 03:38 PM
Northernbob's Avatar
Default Cheap servos and Spektrum receivers
I have a cheap Amazon 20kg servo (Zoskay DS3218) that will not work on any of my spektrum receivers (SR210/SR415). I had installed my Spektrum receiver and it worked great the the stock servo. I thought id "upgrade" to a stronger servo. The stock servo was removed working. I have tried everything I can think of and had to eventually put my TRX4 sport back on the TQ radio where it works fine on the cheap servo. I verified all the spektrum receivers worked in other vehicles after I tried in the TRX4 and there were no issues steering and throttle work just fine. All the servos I tried on the spektrum receivers when in the TRX4 would not work. They all worked on other vehicles with the same spectrum receivers this includes the stock servo. I did not try the cheap servo on my other vehicles wasn't sure what was gong on at that point. The TRX4 has the XL5hv in it. Radios are DX5C and DX5 pro, receivers SR210/SR415. I really want back on my Spektrum radios as I have more control over everything compared to the steering trim only TQ radio.
I'm just trying to make sense of this.
Any thoughts?
Northernbob is offline
Old 05-28-2019, 04:11 PM
frewster's Avatar
Sounds like a problem with not enough power getting to the RX in the TRX for the more power hungry servos. You might need a stronger BEC.
frewster is offline
Old 06-02-2019, 12:04 AM
RazorRC's Avatar
Yup, I agree. I run the 20kg Zoskay servo on a fake Spektrum cheap DSM2 receiver and it's fine, but I have a 6V/3A output on the BEC on my ESC. You probably need at least 2A.
RazorRC is offline
Old 06-07-2019, 05:34 PM
I've got at hobby wing 1080 and a BEC installed now. Made a servo to BEC bypass so no ESC power to the servo anymore. ESC only powers receiver. I still need to solder the XT60 connectors so I can power it up Amazon showed too late and I have to adult this weekend. I watched an Exocaged rc YouTube video servos pull a lot of current. It hasn't been an issue in my race rc cars I have spektrum and savox. The crawler forums first sticky in electronics is get a BEC if you have the same problems I did. I found that after I wrote this, live and learn.
My new set up is not tested but should fix my issues.
Thanks for your help.
