Traxxas BEC
I'm having a hard time finding much info on Traxxas' BEC unit. What I think I know so far is that it puts out 6.0 volts to the servo. I can't seem to find out what the amp rating is and if the voltage is adjustable. If anyone knows more about this I'd be very appreciative.
no info on this part # 2260..https://traxxas.com/products/parts/2260?t=overview
It only puts out 3a. If you are able to, I would suggest a Castle Creations BEC as it is 10a and half the price.
Originally Posted by DRTMI
(Post 15453844)
If you want plug and play, heyok makes a nice plug and play bec that you can adjust the voltage output without an expensive castle link. You can order one with whatever battery plug you need.
on a side note, a 3 amp bec generally is enough amps. Even if your esc puts out close to that, you'll be taking the stress and heat off of you your esc. And the jst connectors are only rated at 5 amps, so don't expect 10 amps on a single servo line.(that's why larger becs have 2 outputs). |
| All times are GMT -7. It is currently 08:06 PM. |
