Brand New Nimh batteries not working? >
Old 05-15-2019, 11:30 AM
Default Brand New Nimh batteries not working?
I purchased some battery packs from Amazon one traxxas hump pack and the other a flat pack. Long story short, they're both dead. No matter how much charge I give them they don't power my reciever - yet I use a AA-battery pack from an old RS4 and it works perfectly.
Is there something I'm missing? Any particular reason this happens? Every NiMH pack I've had tends to just poof.
Solico is offline
Old 05-15-2019, 12:08 PM
do you have a voltmeter? And.. putting a 7 cell pack into a "normal" reciever sounds like a good way to fry it.
Nerobro is online now
Old 05-15-2019, 01:06 PM
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 85 (100%+)
return to sender, Amazon has good return policy.
1/8 IC Fan is offline
Old 05-16-2019, 05:13 AM
Trader Rating: 31 (97%+)
Is this for a nitro or electric car?
If electric, what ESC are you using? Did you disable LVC to use NiMh?
How are you sending power to the Rx? Through the Battery port or through the BEC of an ESC on Ch2?
billdelong is offline
Old 05-16-2019, 08:54 AM
They’re both connecting into the reciever I use for the MX-V Airtronics transmitter I use. I made sure the voltages were within the receivers range. I just feel like they’re not getting any charge?
Solico is offline
Old 05-16-2019, 09:01 AM
If you use the same charger on both batteries, then the thing in common is the charger. You might see if someone local has a NiMH charger that you can use to validate. Checking the voltage of the batteries and trying a different charge are the next logical steps.
Mahjik is online now
Old 05-20-2019, 04:49 AM
Good point Mahjik, I will test out a new charger and see if that fixes my problem. I didn't even think about that.
Solico is offline
Old Yesterday, 12:16 PM
Trader Rating: 50 (100%+)
He has purchased 5cell hump and 5 cell flat receiver packs for nitro car...
tonyd is offline
Old Yesterday, 12:18 PM
Have you checked the voltage of the packs??
tonyd is offline
Old Yesterday, 12:49 PM
the rc guy's Avatar
send back or attempt to.i purchased a few dud nixx cells b4
the rc guy is offline
