-   -   Smallest charger out there? (https://www.rctech.net/forum/radio-electronics/1043026-smallest-charger-out-there.html)
Gyr0 05-14-2019 12:16 PM
Looking for a new charger and want to keep it small. What's the smallest one out there with a built in power supply preferably. I know the x6 is tiny but you also have to haul around a brick for it to work. I know the hota d6 isn't so bad plus its two channel
1/8 IC Fan 05-14-2019 12:28 PM
SkyRc B6 Lite is a small DC charger. 76x85x37mm
scott_0 05-14-2019 12:31 PM
the icharger x6 is a pretty small one, very capable
https://www.amainhobbies.com/junsi-i...jun-x6/p773438
EbbTide 05-14-2019 01:09 PM
Hobbymate d6 pro duo is my new favorite ac/DC charger. It goes up to 200 watts and can actually fast charge two 2s batteries side by side.
Andy Koback 05-14-2019 01:45 PM
iSDT D2. Dual output @ 12A per channel. AC input only. 4" x 4" x 2 3/4".
Di_spencer 05-14-2019 03:06 PM
+1
platgof 05-14-2019 07:36 PM
I Charger 206 and a HP750 power supply
Andy Koback 05-14-2019 07:43 PM
[QUOTE] smallest one out there with a built in power supply.
BRSracing 05-14-2019 10:09 PM
ISDT chargers are not reliable. Had two both broke. Company is little to no help as they are not in the USA
big ted 05-14-2019 10:43 PM
Fyi the Hobbymate d6 pro duo & the ISDT D2 AC are essentially the same charger in different packaging, except the Hobbymate has wireless phone charging if you're into that.
Also worth noting that there's a DC only version of the ISDT charger so don't confuse them.
I'm very happy with my Hobbymate d6. The fan broke when I knocked it off my pit table, but I was able to replace the fan with a similar spec one from Digikey for $20 & it's back in business.
Scrubb 05-15-2019 01:55 AM
iMaxRC X150. 8 amp charge with the built in power supply, color touch screen. USB port for charging your phone. Small. Mine works great. $50.
iMax 150
http://pict1.ec-sites.jp/img/1028/14...0113121557.jpg
GuyIsDamGood 05-15-2019 02:42 AM
Check out the Hitec X1 with the E-Powerbox.
Roelof 05-15-2019 03:40 AM
For what purpose, what kind of batteries?
It can be very small if it is only for receiver batteries....
Kaifd3s 05-15-2019 10:08 AM
Here's a small one from Yokomo.
https://www.amainhobbies.com/yokomo-...SABEgI3KvD_BwE
frewster 05-15-2019 11:18 AM
Yikes. That's $100 for a 50W charger.
Powered By: vBulletin v3.9.3.6
