-   -   sanwa super exzes battery box (https://www.rctech.net/forum/radio-electronics/1042642-sanwa-super-exzes-battery-box.html)
cqb1911 05-07-2019 04:06 PM
hi all,
i just bought this radio, used and without battery.
therefore i'd like to ask you:
- which voltage must be used?
- must the black wire be at the center or at one side of the plug (and which one)?
in case i use wrong voltage or i swap the cables, i will fry my radio, isn't it? :confused:
Roelof 05-07-2019 10:46 PM
You can download the manual at Sanwa.
cqb1911 05-07-2019 10:51 PM
i own the manual, nonetheless i still need these clarifications
cqb1911 05-07-2019 11:09 PM
indeed you're right, there's a little picture that shows that the + is at the center.
thanks
cqb1911 06-27-2019 05:15 AM
this is what the manual says...
i65.tinypic.com/rbm6h3.jpg
i followed the instructions but the radio doesn't get on.
is there anybody here that can please take a photo of the battery box to show me how these damn cables must be set?
Also, are 8AA okay?
MiCk B 06-28-2019 02:12 AM
Also, are 8AA okay?
Hi,
Can you post a picture of the front of the transmitter.
Want to be 100% what version of the Sanwa exzes you have. I've a couple here and I'll check battery configuration for you.
MiCk B. :-)
cqb1911 07-04-2019 11:43 PM
http://i68.tinypic.com/mvg4zp.jpg
i've put a link in the title
MiCk B 07-05-2019 02:08 AM
Hi,
I'll take some photos over the weekend and post them for you.
MiCk B. :-)
MiCk B 07-08-2019 04:50 AM
Hi,
This is what I have:
https://cimg9.ibsrv.net/gimg/www.rct...07247b2f3f.jpg
Battery box:
https://cimg2.ibsrv.net/gimg/www.rct...2082733dee.jpg
https://cimg4.ibsrv.net/gimg/www.rct...569b5fe05b.jpg
The Sanwa Super Exzes is the last of the 'old' version of the Sanwa Exzes series. It uses a 3s lipo or 8 aa batteries and the connection is the (very) old Sanwa style. (It is opposite to the now standard Futuba order.)
So as per the photo, negative is the middle connector, positive is the top connection. (Note this is the reverse of the now standard Futuba order.)
Hope this helps. Any questions, just ask.
MiCk B. :-)
cqb1911 07-08-2019 12:08 PM
thanks Mick!!!
the manual was not clear, and i think that having connected the battery the wrong way damaged my radio unfortunately...
i'll ​​​​​​ get in touch with a radio technician, hoping the problem can be easily (and cheaply) solved.
MiCk B 07-09-2019 04:22 AM
Hi,
No problem at all. If I remember correctly there is a tiny (surface mount fuse) along the power track, coming from the pins where you plug in the battery. It's a small black square along the copper track (I think).
You need to take the transmitter apart to find it.
Basically follow the track on the PCB board from where the battery plugs in.
MiCk B. :-)
Powered By: vBulletin v3.9.3.6
