Hitec Power Peak D7 AC/DC Charging Station
Hi Everyone - I have a few questions surrounding this charger. The instruction manual is sub-par at best.
First, is there a way to save and name each setting? At the top of the menu, it indicates (1) - Memory - name... but it doesn't appear I'm able to edit it.
Second, the LiPo battery little manual doesn't say was the Terminal voltage control limit is per cell. The charger was set at 4.2v, I assume this is correct for the standard Gens Ace LiPo (or most for that matter?). I'm charing 2s LiPo's and 4s LiPo's. I believe 4.2v would be the TVC and 3.2v for cut of in the ESC as usual.
Those are the couple of questions so far. When it comes to storage - that'll be a whole different animal!
I guess since nobody has an answer, I'll call the manufacturer and ask then post up what I find out.
