Like Tree700Likes
FlySky Noble NB4
Old 09-20-2021 | 12:06 PM
  #991
P2's Avatar
P2
On a positive note I was able to bind my MR-03 Mini Z without a hitch. The new module was plug, bind, and play!
frewster likes this.
P2 is offline
Old 09-24-2021 | 07:32 AM
  #992
P2's Avatar
P2
Originally Posted by P2
The BeaverHobbies GMR tutorial is probably the way to do it, my laptop is very old which could be the reason why it's not updating. I'll try a newer PC later this week and report back if it works.
Update: was able to force update the RX, it's 3rd party so there is another procedure.
Here's the video:
TOM MAR and frewster like this.
P2 is offline
Old 09-26-2021 | 10:38 PM
  #993
RockinTheCasbah's Avatar
I wonder if they could update firmware to get a micro SD in the expansion port? At model 19 of 20 right now.
RockinTheCasbah is offline
Old 09-27-2021 | 01:03 PM
  #994
frewster's Avatar
Looks like the pro model is coming next month. Other than inductive charging for the base I'm not sure what the differences will be.
frewster is offline
Old 09-29-2021 | 06:45 AM
  #995
Keeping an eye out for this. SD card expansion for extra models would be nice as mentioned above even though I don't particularly need that.
Werty Yui is offline
Old 10-04-2021 | 10:19 AM
  #996
Why would an SD slot be needed for that? It should be simple enough to do that through a firmware update (if there's enough storage capacity). If there's not enough storage, then, maybe, with the upcoming release, it could (among other things) have additional storage to accommodate additional model memory. It's no different than, say, a phone or tablet...just install a higher-capacity chip.
gwc likes this.
Panther6834 is offline
Old 10-04-2021 | 05:11 PM
  #997
frewster's Avatar
Contact FlySky suggesting more model memory. They've been receptive to my suggestions in the past.
frewster is offline
Old 10-07-2021 | 03:48 PM
  #998
Sir, you asked then answered your own question.
Old 10-07-2021 | 03:53 PM
  #999
No...I was simply responding to someone else's post. It was someone else who brought up the SD card.
gwc likes this.
Old 10-07-2021 | 10:27 PM
  #1000
I've been in contact with William rc at fly sky about it, but looking at the fcc documents for the new model it looks to be an aesthetic and ergonomic upgrade only for the pro model. We will known in a couple days for sure.
Old 10-07-2021 | 11:00 PM
  #1001
That doesn't make any sense, as the FCC has no control over "aesthetic and ergonomic" design. FCC would be related to electronics.
Old 10-07-2021 | 11:16 PM
  #1002
https://fccid.io/N4ZFG400/amp
Cromulent likes this.
Old 10-07-2021 | 11:30 PM
  #1003
The change, as stated in the filing, has to do with "Class II electronics". Yes, this new model might (and, probably does) involve physical design changes (which we know our does, per the photo of the new wheel)...but, the primary purpose still involves changes to the electronics. As you said, we'll know soon enough.
Old 10-08-2021 | 05:36 AM
  #1004
There's pictures in the FCC filing... https://fccid.io/document.php?id=5332013
Looks like they've spiced it up with some silver, added wireless charging, and played with the switches (thumb lever on ch4 and maybe redesigned SW5/6. I do not see an SD card slot.
gwc likes this.
Cromulent is offline
Old 10-08-2021 | 08:38 AM
  #1005
That Ch4 thumb control (if that's what it is), I like. Imagine, on a crawler, setting that to control a 3-position dig...could instantly change dig positions without having to move hands from their position. Or adjusting steering rate on the fly. Or drag brake. Again, to without having to change hand positions. Nice!!!!! As for an SD slot, in regards to expanding model memory capacity, I still don't see any need for one...simply increase internal storage. But, I do see other uses for an SD slot - firmware upgrades, and export/import saved programming, without needing to plug the Tx into a computer (that's how it's done on the Futaba 7PX). An SD slot could be placed almost anywhere (on the 7PX, it's "hidden" behind the 90-degree rotating antenna)
gwc likes this.
