FlySky Noble NB4
#586
Well, I been testing on my 2wd, radio is not going in full throttle. So now rally confused. I'm wondering if ESc can cause a memory to over ride radio memory, which well give it a reading at full throttle. Car runs fine if I dont turn off radio when connected to 4wd, but when I turn off both and let radio sit for 30 min, I'll turn on radio and I check calibration and that's when I see it's on full throttle. I dont want to do this everytime when I turn on car , especially for a race
#587
Trying to preemptively make a sun shield for the noble. First print attempt. As is often the case, not 100% happy with the first draft. didnt slide over the steering wheel arm well at all, and I think its a bit too short to block as much sun as it may need to.. Making adjustments.
Never mind I made my own
#588
I flashed the standard 85, but this happened before, when I got it was 79. I'm wondering if somehow its reading something when the my car is running , maybe from ESC on car? Than when I turn off it has a bad calibration in memory? It runs fine , when I recalibrate the stick after a few minutes to try to get it back to normal. This so weird, I like radio but it's new havent even taken to track
#589
Well you think can be bad reciever or do we need to program a failsafe on radio?
#590
I actually never set a failsafe, and I recieved two fgr4s. I'm using a Arrowmax Dash esc, which I calibrated after binding to radio. So I tested my 2ed buggy and doesnt happen to radio. I'm wondering if it could be a sensor wire? Or maybe the reciever gets a bad signal after turning off is why radio sees it as full throttle? I downloaded the standard 85 , I live in Sacramento CA. So not sure if I need to download FCC.
#592
This picture shows I just turned on than went to stick calibration, this after I let it sit after 20 mins. Car is off too.
#593
Here when I turned on after running again and leaving the car off. Radio sat for 20 min after turning on. ch2 is set to full throttle .
#594
Well, but still, when I bind in 2-way mode, the servo reacts directly after the binding process is complete. Even with the bind plug still inserted and no off/on cycle of the receiver.
In 1-way mode, it doesn't, only after I turn off the receiver and turn it on again, the servo works.
Andreas
Andreas
Hello:
In 1-WAY mode, when the receiver completes BIND, the indicator light will flash from fast to slow. When the BIND line is removed, the transmitter exits and the receiver indicator light will always be on.
In 1-WAY mode, it is necessary to re-code the steering gear response speed to change, and our subsequent firmware will be improved.
Thank you for your support of FLYSKY products.
#595
#596
FGr4P JST-ZH 1.5mm mod
I know the micro receiver is coming out but the project must go on.
It was pretty tough removing all the pins because the tray is held down with glue or something. Took me more than an hour to do what should have been 10 minutes job. At the end of the day it's not really worth the board mutilation. Just wait for micro receiver if you want low profile receiver for 1/28 car.
#597
Still looking forward to getting this in my country.
#598
Showing in stock in the china warehouse.
Flysky Noble NB4 AFHDS3 Surface Radio w/2 x FGR4S Receivers | HobbyKing
All gone
All gone
#599
R/C Tech Elite Member
Got my T-Works skin in today and installed it. Came pretty quick from overseas given the pandemic situation .Ordered on June 22. I was surprised with the quality of the stickers. They are fairly thick and will take a beating while keeping the controller safe. Went on fairly easy and there were no major fitment issues. some of the holes for screws didnt line up 100% but it was acceptable. Also had to trim some slight overhang but nothing major. Gotta say I really like the skin overall.
#600
