Soldering Iron Suggestion
Hello, I'm looking for a soldering iron to take to the track which most of the time is out doors. I need to be able to solder 10AWG wire for my 1/8 buggy as well 1/10. My current track iron does not get hot enough with a little wind blowing.
Suggestions?
Suggestions?
I really like the Hakko FX888D
But for pure hobby soldering and for value the FX-888d is the way to go.
Trader Rating: 53 (100%+)
Another big vote for the Hakko FX-888d. I have a Checkpoint TC950 station as well but for whatever reason I prefer the Hakko.
ceh329, even the trak power tk-950 can do exactly what you ask. Just need to be patient when soldering and use a good "quality solider". Can't stress that one enough! Buy good solder! Keep your tip clean and tinned and your soldering talent will increase dramatically trust me. Get some Miniatronics solder, some flux paste and a good metal brillow pad / wad tip cleaner and report back. No wet sponge needed... This solder melts and is usable at a much lower temp than most and will help to improve your soldering. A good solder sucker is also a must for a beginner. No that is a real thing too. Does what it's title says. If you goof up, it can help clean up your mess.
So it sounds like the Hako is the most recommended. The FX-888d will work great outdoors?
You'll also want to make sure you use the right tip. You'd want at least the 3.2mm hakk tip, but for 10ga the 5.2mm will work better although not necessary. If you were using a small chisel tip prior to this then that could have been hurting you at the track.
I manage a team of 25 military wire harness assemblers that build to IPC, J-STD and NASA standards for a living 50+hrs a week. We literally just ditched our Hakko stations for Weller. The Hakko stations typically last 1.5years of 50+hrs a week use. The Weller stations are a bit more money, but they have easily lasted 5+ years with the same yearly calibration, and preventative maintenance we do on all of our solder stations (Hakko or Weller).
The Hakko stations are good for hobby grade, but that is about it. Wellers can be calibrated to show an accurate temperature instead of being 15-20+/- degrees off.
If you want a good tool because tools are an investment, buy a Weller. If you want something to do the job well for 1-2 years before you have to buy another one...buy a Hakko.
I personally have a Weller and Hakko in my garage at home, The Hakko hasn't been used in about 2 years.
I have a genuine Fx888D I don't need anymore. With some extra tips I.d sell... Pm me if interested.
