-   -   Trinity mod rotor options (https://www.rctech.net/forum/radio-electronics/1040499-trinity-mod-rotor-options.html)
Doug10 04-05-2019 05:34 PM
can someone that is experienced with the trinity mod rotors hit me up via private message. I have questions about rotor selection. Thanks much.
Roelof 04-06-2019 12:58 AM
Originally Posted by Doug10 (Post 15426698)
hit me up via private message..
Why that? You want to know something no one else needs to know?
billdelong 04-06-2019 07:53 AM
Trinity mod rotors are legit, I bought a meter to check the stats for myself just to make sure I wasn't getting ripped off.
There are several options to consider, and our club allows the Punisher, I pulled out the rotor that came with the motor and got a reading of 1610 mG which is right on the fringe of being a certified rotor:
https://live.staticflickr.com/7825/4...e8f437a108.jpg
The highest ROAR legal rotor you can get is the TEP1119CX Strength Level: 1675+
I bought the Team Spec 13.0mm Ultra High Torque Rotor - Gold (Outlaw Stock) and got a reading of 1934 mG... yeah buddy!
https://live.staticflickr.com/7839/4...cba73b49d6.jpg
Unfortunately my meter maxes out at 2000mG and sure enough my larger 4WD SCT rotors could not get readings with it and I'm not willing to spend more than $30 for a gauss meter, , ha!
Doug10 04-06-2019 02:14 PM
Looking for suggestions on rotors for non-off-road application. Picked up two 7t’s came with the blue rotor. After briefly talking with the folks at trinity they thought it may work good for our application for a mod motor with smooth power Our application is sct based oval conversions at about 90oz. Tracks are higher grip, carry a lot of speed and out of the throttle very little. I would have thought the red rotor was ideal but looking for ideas. Mod motors are new to us, we had been running 13.5 before and seems most folks are off-road folks wheee I believe you run the strongest rotor you can to pull the chunk a monks out of the turns to get over the jumps. Too much initial torque power for us isn’t as good because it will blow tires loose but we need it down the straights. I don’t mind adding boost but figured I’d see what seasoned mod guys would suggest.
billdelong 04-06-2019 02:27 PM
I recently got into 2WD Mod SC Oval with MWM bodies and most of the seasoned pros in my area are running 4 Pole SCT motors in the 4800KV range... I have seen some guys run 540 sized 7.5T motors but they aren't keeping pace... at the very least I would go with the highest torque rotor that I linked before (Outlaw Gold) if you want to have a halfway decent setup, but would seriously reconsider getting a 4 Pole SCT motor unless your club is limiting to 540 motors.
Doug10 04-06-2019 04:46 PM
Nah I’m good on 4 poles.
