-   -   Made a diff checker (https://www.rctech.net/forum/radio-electronics/1040085-made-diff-checker.html)
b.wihardja 09-09-2019 05:48 PM
papagogo 11-14-2019 08:24 AM
Juglenaut 11-15-2019 08:40 PM
I would rather buy a vacuum tool that removes all the air from the diff rather than some checker. Regular rebuilds cost less than one checker. Having several diffs built at different CTS, I personally see this as a vanity tool while it may provide consistency in theory with numbers, the best method is to rebuild as the data is presented in variables that often times are irrelevant. My point imho is that if you open a diff to top it off.. change the oil, if it is leaking replace bad seals, outdrive, and or, case I believe this will provide more consistency hard or soft. After all the engineers that developed the oil are in theory correct.
gigaplex 11-16-2019 01:34 AM
Removing the air bubbles from a diff is pointless. You will trap air in it when you seal the case, and the moment you spin it up, it emulsifies the air back into the oil.
Roelof 11-16-2019 05:49 AM
The experience as with shocks is that more or less a drop of oil can make a huge difference. Going a small step lighter in oil but using a drop of extra oil can make a diff and a shock harder. So a meter will check if you did it right. In case of good drivers I think it is wise to see if your change is established or was is wrongly done.
It is like you want more toe-in and screwed it up with a toe out because you did not measure it..
the_real_hova 11-16-2019 06:49 PM
Great work! I had no idea I needed a new tool/project until now!
Stupid question: How (and when) do you use this if the scale is in current and not a torque value? Do you just check the difference between front and rear diffs?
Bry195 11-16-2019 08:42 PM
the measurement scale is so small and accurate that you can check allot of things. I use it to check friction in the drive train. resistance of the motor to a torque is indication of rotor strength. I check if my dif is set right and it will also tell you if your dif is losing oil. if you had an eccentric you could also use it to check your shocks or springs for consistency. I dont use it allot but if something isnt working right it takes to seconds to make a bunch f checks. Not a must have but its nice to have.
papagogo 11-27-2019 10:44 AM
You can check stiffness of different diffs. The valor is not important, the important is the difference between 2 numbers (ex: 1600 is stiffer than 1400)
