I need 13.5T gearing help
I will be running a Maclan 13.5t short stack motor in 2 different stadium trucks. One a TLR 22T 3.0, and a ECX Circuit for my son. I want my son to get his feet wet with racing before I invest in a race grade truck. I believe the internal gear ratio for tlr is 2.43 and ECX is 2.6. The stock timing on the motor out of the box is set at 50 on the Maclan's. I'll be using a Hobbywing Quicrun 10bl 120 ESC if that matters.
I've never driven a 13.5t in a stadium truck, only mod Motors. What would you suggest for gearing for both of these trucks? Thanks in advance for your help.
I would contact the manufacturer or try to find a setup sheet from a pro driver running the same brand of motor... the current generation of short stack motors are all over the place with gearing ranging from 23/81 to 31/81 with different brands of 13.5T motors in the same 4WD Buggy I have raced with. When all else fails, check the manual with the motor to see if they provide a gearing chart, no matter what, be sure to check temps:
What gearing do I need to run for upgraded electronics in my car?
The stadium truck has an IGR of 2.6. What would you recommend as a good starting point for spur and pinion size?
There is a gearing chart in the 22T manual that will give a safe gearing to start with for a 13.5 motor. From that information you can use a calculator to figure out the gearing on the other truck. For the kids truck you could turn down the motor timing 10-15° and gear it a few teeth lower to make the ECX slower if you think the 13.5 is a bit much.
