Servo locking to one side
I got a protek 170t that locks to one side if I tap it it will work for a few seconds then stops again |
Originally Posted by Soyer
(Post 15420814)
I got a protek 170t that locks to one side if I tap it it will work for a few seconds then stops again If it is not, I would contact them for support If they have poor support, I would open up the servo, take the circuit board out and take a look at the soldering of motor to the circuit board. If the motor solder is ok, I would look at the solder of receiver wire and signal wire at the back of the receiver wire soldering |
If it stops at the same spot every time I would say the potmeter but sometimes it can be the motor also.
Contact Protek Amain, They have great CS support, I would not recommend opening it up. Given them the chance to help you out. Is this one of the older Chad Bradley Grey 170T's?
Does it lock with the steering links removed and only the servo arm swinging by itself?
Just want to confirm there is no binding on the links that might be causing a brownout. |
Does it do the same thing with a different servo? |
So I already took it apart the motor stops and runs if I nudge it a bit. |
(Post 15421369)
So I already took it apart the motor stops and runs if I nudge it a bit. My servo is a coreless servo, so it only has 2 tabs... Brushless has 3. If u are not used with soldering... I suggest you to contact your seller |
| All times are GMT -7. It is currently 12:30 AM. |
