Discharging voltage
Just wondering how low (voltage) are you discharging your batteries when cycling them for 17.5 racing. I assume that most of us are not discharging down to 6.0v and then charging?
generally good practice to set LVC to around 3.4V/cell
I discharge to 6.8 at 30 amps on high c 2s batteries. Which after a little rest end up at 6.95 and 10%. 50 or 60 c I discharge at 25 amps to 6.8 but that recovers to like 7.1. I think the moral of the story is that a high discharge rate on a mid to low c battery causes a short term drop in voltage much higher than a high c battery so the voltage they get discharged to really kind of depends on the battery. a 60c 2s 5500 will not sag as much as a 50c 6600. The 50c (both bashers) will puff above 17amps and in my case the 60c didnt puff at 25. |
I find very little performance discharging.. 6,200mah and 120c... 30 minute rest then recharge at 5 amps.
10.5 or 17.5., Tekin in a SC5M. but that is me. Ni-Cad's needed it .. these do not. |
Thanks for your inputs.
| All times are GMT -7. It is currently 08:27 AM. |
