-   -   Steering Delay when using throttle (https://www.rctech.net/forum/radio-electronics/1037694-steering-delay-when-using-throttle.html)
Jharding 02-24-2019 11:26 AM
I have some old RC cars and electronics from about 25 years ago that I am trying to get to work for my kids. When I first reconnected everything (with a new battery), everything worked fine.
I went move the electronics to another car and overtightened the servo screw and messed it up so it would take stop twitching.
I bought a new in box futaba servo, same as before fp-s148 and now it works again, but I am running into issues with the steering responding when using the throttle. It will be moving and when. I turn the wheel on the transmitter, the stetheng won't turn right away, it's not responsive. I tried this on two different cars and same thing, one with a steering mechanism and one with just straight tie rod connections.
I tried elevating the car to be able to hit the throttle and see the steering up close and it seems better, just when it's away. I even tried moving back and it was fine, so seems like only when on the ground and moving.
Not sure what's up, they are old vintage electronics but worked before I had to replace the service.
Anything else I can try to troubleshoot?
1/8 IC Fan 02-24-2019 11:28 AM
Is your battery fully charged, are you running a receiver pack? If any of those voltages fall out below the Servos requirements you will get a delay aka. a brownout until there is enough voltage to supply the demands of the Servo(s).
the rc guy 02-24-2019 11:37 AM
more than likely the bec on the esc is failing.so you have 2 choices. get a bec or ubec and remove esc to rx center wire.. or add a rx pack.https://www.bing.com/images/search?v...vt=0&eim=1,2,6
