-   -   Motor connections (https://www.rctech.net/forum/radio-electronics/1037550-motor-connections.html)
atholliday 02-21-2019 08:22 PM
Motor connections
Hello, what is a good connector plug to use on the motor and esc if you want to switch motors to race different classes. I’m looking to run off road stock 17.5 blinky then swapping motors and running dirt oval with a 21.5 turn in blinks mode and want something that transfers good power with out soldering all the time. Thanks in advance.
1/8 IC Fan 02-21-2019 08:32 PM
I have used these quite succesfully in spec handout racing.
https://www.amainhobbies.com/castle-...0007-00/p34141
StevesZZ5 04-03-2019 11:17 AM
3.5mm connectors are your best bet, they’re by far the most common.
the rc guy 04-03-2019 11:43 AM
4mm id have to say are most used ..
