Protek 625 Duo Charger
#16
I'm in the market for a new charger, partly because I was already considering one...and partly because both of my other chargers (Traxxas ID Dual Live, & Hitec X2 AC Plus Black Edition) went "goofy" (the first died after less than 5 months use; the second (after only 3-4 months) started indicating "DC IN TEMP HI" & "EXT.TEMP TOO HI", even though nothing is connected) on me a week apart. Like others, I was initially considering the Junsi iCharger 308DUO, or 406DUO, but the price, and the fact that both require a separate power supply (thus doubling the cost), helped eliminate that idea from my mind. While the 625 can operate on AC, it does have a DC input, but I've run into a "problem". Listings for (almost) all 'quality' chargers provides all input & output-related information...but AMain/ProTek has interestingly "forgotten" to include one seriously-important piece of info - the Maximum DC Amp input. The info clearly states the charger's Maximum Amp output is 25A/channel, thus one might assume the Map input is (possibly) in the 50A-60A range...but such is not guaranteed. Without this info, it makes selecting a power supply difficult, if not impossible. Neither AMain's own website, their ProTek website, nor the user manual appears to have this much-needed info. So, does anyone know what the Maximum DC Amp input is?
Also, in regards to firmware updates, as with the Max DC Amp input, there is no info to be found. The manual says nothing about firmware updates, and the ProTek website doesn't even indicate this charger exists. Have there been any firmware updates? If so, where can they be downloaded? Also, if so, how does one install the firmware update? Inquiring minds want to know.
#22
Well, I made the mistake in opening the Pro Duo as one of my fans was making a noise. Come to find out the board is by EV-PEAK. So went to their site, and there it is
https://www.ev-peak.com/prodcuts-item/ev-peak-cd3/
Then Amazon has it on sale for $150.
So ProTek has it with a $100 markup, the only advantage you get with this is warranty through AMain for one year. I have had mine for way more than that, the actual board has a stamp on it of 2016. Maybe it is time to order a new one.
I contacted EV-Peak to see if there is a firmware update for this charger and there is not unfortunately.
I have an issue with the Reedy 2s RX Lipo packs where for some reason it will not charge or discharge correctly. i get the voltage per cell go all over the place until the charger decides to error out. I get the same issue with three different Reedy packs.
#23
My thanks to OP & sebtarta!
Added this as my 3rd charger as I've needed another charger. Except with the duo function... I essentially have 4 batts that can be charged simultaneously (we have 5 drivers & 11 batts currently).
FYI, Amazon has it currently for $159.99
AND there is a $20 coupon that is applicable at checkout. Just bought it and it works.
~$150 with tax
If I purchased the wrong one, someone please tell me right away so I can cancel the order.
link:
thank you Seb
as stated before, not having to add an additional cost power supply to go AC makes this a more realistic option financially than the iCharger Duos
~$150 with tax
link:
thank you Seb
#24
~$150 with tax
link:
https://www.amazon.com/EV-PEAK-400W-.../dp/B01NAN7JQ0
~$150 with tax
link:
Yup, that is the one.
#26
I see there's activity on here so I'll post my almost 1 year update.
It gets used pretty heavy. Club racing, bashing, etc.
Its been pretty flawless. I have noticed however that the IR readings are off on one of the ports, even for a brand spanking new battery. Possibly the balance board. I guess we can use any balance board that supports 2s - 6s? I'll look further into it and hope its JUST the balance board.
Also good to know the "original" is on Amazon for $100 bucks less in case of anything.
#27
If you start looking around at some of the offerings by the ”discount” hobby stores online, that same charger is sold as two or three different brands (I’ve seen alternate versions of their 610 model as well). Now, what might cause the different pricing? Aside from the customized appearance, certainly the guarantee, perhaps higher grade packaging, not to mention maybe a customized version of the firmware and perhaps even someone in house to update it as needed.
I’m sure the “generic” ODM versions perform similarly, but if something happens to them, you are on your own most of the time. Is that difference worth $100? Honestly, that’s an individual decision.
(Full disclosure: I own a 625 myself - no problems at all, and I’m happy with it for my needs.)
#28
I contacted EVPeak regarding the firmware update for the 625 Duo, they have been more than helpful. I have to send them some pics and then I will have more info on how to manage to update the firmware.
It all started, because the PSU fan is failing. lol
#30
Ive had mine for over four years since just after it came out. The only long term issue I can see is the second channel IR readout is way off compared to channel one these days but it still works and charges just fine so I just use channel one for a quick IR estimate these days. (chargers aren't very accurate at IR in general so take your readings with a grain of salt, only professional ESR analyzer-style IR meters can accurately measure IR)
