-   -   Battery Connectors for Lipo (https://www.rctech.net/forum/radio-electronics/1036111-battery-connectors-lipo.html)
strex 02-01-2019 03:38 PM
Apologies if this thread is similar to other - but I did a quick search and could not find answers...
What battery connector should I use for buggies - Team Associated B4.1
I currently use XT-60's but people have said that they are not correct and should be used for planes..
What should I use Dean T's, EC3's or others..
Is there a standard for different vehicle, drones, planes boats etc??
Thanks in advance.
Billy Kelly 02-01-2019 03:46 PM
Take you pick. EC3, EC5, deans, Traxxas, XT-60. I’ve got vehicles using all of these. And few more. Few of mine use bullet plug directly into battery. It’s more of a personal choice. Some do hold better in rough driving.
the rc guy 02-01-2019 03:58 PM
you can use any connector you want as long as it meets the esc needs I have been using xt90 for several years ..
RazorRC 02-01-2019 05:54 PM
Since Horizon Hobby owns half of the RC companies out there and they use EC5's, I've switched to using EC5's for my bashers/crawlers. For race kits, I go direct into the battery.
MaX-D 02-01-2019 06:01 PM
Stick with the xt60 plug you have. There's nothing wrong with it. It's a great plug, and won't come unplugged bouncing around inside of a buggy.
fredswain 02-01-2019 06:18 PM
The XT plugs are awesome plugs. I got rid of all my Dean's and went to them.
MaX-D 02-01-2019 06:58 PM
I also want to ditch all of my Deans plugs and go with xt60 or xt90 plugs. Are XT plugs easy to solder? I only Run 2s lipo on my vehicles that I drive. What would you recommend, XT 60 or 90?
rustyus 02-01-2019 07:18 PM
After switching from Deans/EC5 to XT60 connectors, I thought to myself...I should have done it years ago. They are the only plugs I'll use from now on. If the LiPo has inboard tubes, I use low profile bullets of course.
MaX-D 02-01-2019 08:03 PM
what didn't you like about the ec5 connectors? How do they compare to the XT type connectors? What XT connector is the best to use for 2s lipo?
Evoking1230 02-01-2019 08:27 PM
XT90 here. Love em. Not a single problem.
MaX-D 02-01-2019 08:32 PM
Is it a good idea to cut the connectors off of batteries and solder on new ones? Are there any hazards to this?
VoltageDrop 02-01-2019 10:07 PM
No not really unless you are really bad at soldering. Just cut one at a time as to not short them out. And make sure you use good solder and have a decent soldering iron 40w or greater. Cold joints are usually created by cheap irons
Di_spencer 02-01-2019 11:33 PM
I work at a hobbyshop so I've soldered on almost every connector there is and I have to say the XT series connectors are much much easier to solder than the EC series.
jersey 02-02-2019 12:19 AM
I’d agree with that also. Some ec5 connectors I’ve had a hard time with locking them into the plastic piece. Also putting the right amount of solder into metal piece it can sometimes come over the side and make a glob and then will be even harder to stick in plastic piece.
I prefer xt60 xt90 they lock together good. Easy to solder. They don’t come apart when driving at all.
rustyus 02-02-2019 04:01 AM
They (EC5) are a pain when you want to reuse them. Too many extra steps to disassemble/reassemble.
For 2S I use XT60.
