lap timer
in my area there any way too many different types of cars to organize. was thinking to build a lap time system using garage door opener safety sensors. they could trigger a stop watch? that way people could race the clock instead of each other, then all sorts of cars can run. any thoughts ?
Why re-invent the wheel? There are several different lap timing systems out there already. Trackmate, iLap, robotronic, mylaps just to name a few. |
If only one car is on the track, sure. But if there are two cars, how do you tell which one is which? Existing timing systems solve this problem by using IDs on vehicles, using transponders. Look into the existing timing systems.
I finished my IR lap timer proyect some months ago. I was able to detect more than 2 cars at the same time, but I ended up buying lapmonitor lap counter as it was cheaper 😅
Take a look to this
https://www.rctech.net/forum/radio-electronics/1002584-rchourglass-diy-lap-timing-aka-cano-revised.html |
10 clicker/counters mounted on a board... one operator........ aka 1980's RC racing.
If it is for just 1 car then a beam is enough. Look arround the internet and you will find enough diagrams and modules how to setup a long range beam with IR and even lasers.
In a far past I had made my own IR transponder mounting in the side of the body and a simple IR receiver. I was able to hook up the receiver its signal to a stopwatch but in that time with MSDOS it was easy to read signals on the printer port so I made a simple program in BASIC to count a 5 minute heat |
try Lap trax its free. it will also work with a few cars.see I read ur 1st post.
Originally Posted by the rc guy
(Post 15387577)
Originally Posted by chuck_thehammer
(Post 15387553)
i build this ir lap counter based on lisergios ricino proyect , https://github.com/cdemetriadis/RiCino-Lap-Counter/wiki
and the rchourglass. the ir lap counter works good and are cheap to build ,but if two cars passes at the same time it only counts one, this is due to the 8mhz clock of the attiny85 , a 16mhz external oscillator can be added to the attiny85 and run in TSOP7000 receiver , but i dont know how to do that . the rchourglass I didn't right and I have poor signal detection |
