ESC HELP!!!!!
I have a xerun justock that I purchased from my lhs. I ran it through a few packs without calibrating it to my radio and noticed top end was lacking a little. I went to calibrate it to the radio(airtronics m8) epa set at 100 and trim set at 0 and once I did the car just shot off like a bottle rocket. It is now stuck in wot with the radio on and will not slow down or speed up with any brake or throttle input. I'm a bit frustrated because I spent $500 at my lhs on electronics, battery, and charger and they weren't able to give me much help with it.
First thing I'd try is to reset everything to default and re-calibrate. Next is go back to the LHS and see if they could pair another radio to it just to rule out the radio .
Would there be any benefit in getting the program card to correct the issue? I was thinking of trying to calibrate it with another radio and just guessing end point settings. When I search the forums there are other instances of this. I don't see why it wouldn't work with a high end radio from ten years ago there's no way i'm dropping $400 on a new radio that only has like two new features.
Follow the calibration as per the ESC manual. ESC manufacturers calibration are different. Sounds to me like you’ve set neutral as full throttle. You should always make these changes without the pinion fitted. Bottle rockets are very dangerous. Example: I always test after calibration does the motor remain still when transmitter is turned off. |
What Matty said, sounds like you set FT on neutral. Default everything and carefully follow manufacturer process. GL!
Originally Posted by party_wagon
(Post 15377486)
First have your car turned off Set your radio EPA at the defaults which I am thinking will be 100 for THrottle EPA and throttle trim at zero. Have brake the same way. Have the car on a surface so its up in the air, wheels can't touch the ground. While hotting the set button on the ESC down, turn the esc on and keep holding that set button down till it starts beeping. Once it does that, you should be able to program it. I don't recall off the top of my head all the steps but it should be in the manual (its something like Neutral, FWD, BRK. Or Neutral, BRK, FWD). If you find it has trouble setting BRK or FWD, try reversing the throttle channel on your radio and then do setup again. |
my thoughts were the channel is reversed for throttle
One idea. Can a m8 receiver handle lipo?
Originally Posted by mdwaeracer
(Post 15380053)
| All times are GMT -7. It is currently 09:18 PM. |
