The only arguement to choose a higher voltage PSU is just that a lower output current is needed making it cheaper.
But because ther is more to run on 12v like tire heaters, pit light etc the choice for a high power 12v PSU is much wiser. |
Originally Posted by Roelof
(Post 15373607)
Originally Posted by gigaplex
(Post 15373947)
The X6 is a bit special. There are some situations where it does need a higher voltage PSU to output max power. But not for 2 cell.
if you knew how 12 volts DC is boosted to a higher DC voltage.. its costly.. and sucks lots of amps..
ac is just Different and much easier to up boost.. |
| All times are GMT -7. It is currently 04:49 PM. |
