Recommended motor bearing removal tools? >
Old 01-09-2019, 04:14 PM
Tech Legend
Cain's Avatar
Trader Rating: 253 (100%+)
Default Recommended motor bearing removal tools?
What tools to you guys recommend for 540 sized motor bearing removal?
Cain is online now
Old 01-09-2019, 07:06 PM
ta_man's Avatar
Trader Rating: 154 (100%+)
When I need to remove a bearing of a size that I do not have the exact proper removal tool for I use long socket head cap screw, a washer on the head of the screw, the closest fitting 1/4" drive socket and a nut on the other end of the long screw. I hold the nut in my vise, tighten the screw and heat the assembly with a heat gun to expand the aluminum and soften any locking compound while tightening the screw to get the bearing to pop out.
ta_man is offline
Old 01-09-2019, 10:47 PM
BRSracing's Avatar
Trader Rating: 62 (100%+)
https://www.teamtrinity.com/trinity-...l-tep3080.html
BRSracing is offline
Old 01-10-2019, 04:24 AM
a person would have a hard time making one like that any cheaper.
I know,, I made a similar one.. years ago for brushed mod motors.
chuck_thehammer is offline
Old 01-10-2019, 07:35 AM
Trader Rating: 31 (97%+)
Here you go:
Muchmore bearing removal tool
billdelong is offline
Old 01-10-2019, 10:55 AM
I have one similar to those posted - I think it's a Fantom.
In general, the pinion side of the can is easy. The sensor board side of the motor can be a challenge - most manufactures do it differently and there probably won't be an obvious stock solution with any of these tools. The last one I did was a Reedy motor, took me awhile and I had to add washers and spacers, and in the end it was like - Oh well, let's just go for it
belewis01 is offline
Old 01-12-2019, 05:54 PM
MaxRain's Avatar
I have and use the Motiv motor bearing tool. It has adapters to accommodate different sensor board styles and after testing, it works very well. You may pay a little more for it, and if you are not brand loyal, it will pay for itself in the long run.
MaxRain is offline
