-   -   How close mount esc to receiver? (https://www.rctech.net/forum/radio-electronics/1029995-how-close-mount-esc-receiver.html)
JeffofSpace 11-12-2018 08:18 PM
There you have it...how close can you mount them. Seems like a lot of heat to mount them back to back like I’ve seen on some builds where the esc is literally double sided taped to the esc.
prorcguy 11-12-2018 11:17 PM
my receiver is about a centimeter away from my esc and Im pretty sure most people running touring cars have a similar setup
Billy Kelly 11-13-2018 03:40 AM
Depends on the servo I’m using. With a low profile servo, receiver usually gets mounted next to esc. With a standard sized servo the receiver usually gets mounted on top of the servo
chuck_thehammer 11-13-2018 04:59 AM
I mount the receiver on top of the steering servo.. if possible.
esc is mounted as close to motor as possible.
my SC5M..... esc is mounted on top of the battery bridge.. receiver is on top of servo.... all weight is balanced on center line.
works for me.
Sir 51D3WAYS 11-15-2018 10:09 AM
Right next to each other is fine, but try and position the receiver such that the antenna trails away from the esc.
