-   -   Replaceable plug in wires for transponders (https://www.rctech.net/forum/radio-electronics/1026749-replaceable-plug-wires-transponders.html)
Core Creations 09-25-2018 10:22 AM
Why have MYLAPS or MRT not thought of doing this yet? They could easily have replaceable plug in wires for transponders in all different lengths like a sensor wire. Seems like a no brainer.
Andy Koback 09-25-2018 11:57 AM
They wouldn't be able to sell new transponders very often. Money maker for them as is. -(
Roelof 09-25-2018 12:34 PM
I also think dirt and moisture can affect the reliabillity of the contacts in the open.... solder tabs would be a better idea.
Core Creations 09-25-2018 01:06 PM
Why would it be any different than the receiver plugs? I’ve never seen a Rc plug contact fail because of dirt/moisture. Maybe broken frayed wires but not dirt. I think the solder tabs would be ok but what happens when’s the case gets all burned by a noob like they do with their ESCs?
Just put a replaceable rubber grommet around the plug.
the rc guy 09-25-2018 01:22 PM
I have put a rx plug on a few transponders and had to go back and hardwire them and remove mod due to bad looks when trying to sell. peeps that bought passed those by..
Roelof 09-25-2018 01:35 PM
Because there is more than only electric onroard racing (looking at your avatar and signature) like offroad gas racing in dirt and mud
rcbuggy88 09-25-2018 02:37 PM
also looks better. you can just open it up and resolder when changing wires, but you should only need to when changing classes.
Core Creations 09-25-2018 02:38 PM
What does my avatar have to do with it? Assume....
What do 1/8 off-roaders and 1/10 buggies do with their electronics now? How would this be any different. Suddenly this one connection makes the idea useless? Don’t like a plug, get the hard wired version. All the other 90% of racers would like the option.
My point is as of today, if your transponder wire gets messed up you’re screwed. You can hack it together which always looks like crap or some even hack into the case which looks like crap too.
Core Creations 09-25-2018 02:51 PM
so you’re suggesting internal solder tabs? Hmm...there’s an option. I’m just thinking for
folls that aren’t great at soldering (more than you’d think) that a clean plug would be a great option.
Phillip F 09-25-2018 11:41 PM
https://www.amainhobbies.com/mylaps-...10r147/p798654
Someone said the new model is easy to work on. Hopefully its true.
Roelof 09-26-2018 01:10 AM
All 1/8 buggies have a receiver box where receivers and its connectors are hidden from dirt etc.
Looking at many 1/10 buggy races they are done on carpet tracks, indoor and eve outdoor. But running in wet I asume the receivers are protected by Plasti-dip, baloons etc.
The old RC2 transponder has actually large internal solder tabs but you have to cut out a large square from the back of the transponder to reach them. Once my old RC2 transponder had bad wires, I added a small PCB with solder tabs.
Untitled Document
Core Creations 09-26-2018 06:54 AM
https://cimg9.ibsrv.net/gimg/www.rct...acfc280f4.jpeg
Here’s a prime example...currently on eBay.
EbbTide 09-26-2018 07:12 AM
There may be a few reasons. One is possibly cost. If they reinforced the TP to still be water resistant with a detachable plug instead of direct wires then the cost of the end product could increase making them even less desirable pricewise than they already are.
In my opinion any average Joe can coil up their wires and zip tie them if the stock wire is too long. And if they are sick of zipping them up then I think at that point it's time to break out the servo wire crimp tool so you avoid a job like that ebay one. And the crimp tool is not difficult to use.
rcbuggy88 09-26-2018 09:28 AM
That ebay one is pretty ugly. Just use the crimper.
