Broken switch hobbywing 10BL50 RTR >
Old 09-04-2018, 02:06 AM
Default Broken switch hobbywing 10BL50 RTR
Hey guys i have a problem ...my switch on my hobbywing esc is stuffed. ..coped a rock...its a 10BL50 RTR...it has 2 red wire's and one white. ...how can i bypass it completely. ..any help would be appreciated. .cheers
Kaine is offline
Old 09-04-2018, 01:58 PM
the rc guy's Avatar
not really sure you can eliminate that switch .since its used to turn esc on and do so selecting thru it,, best bet is to find a schematic or esc and switch. white is negative and red is positive good luck..switch is on/off and momentary on..(to program)
the rc guy is offline
Old 09-04-2018, 03:52 PM
Roelof's Avatar
It contains 2 pushbuttons, can not be that hard.
Do you still have the switch board? Cable is teared off?
If just the cable is teared off you can resolder a new cable, if you have lost the switch board you can buy 2 small PCB tactile switches and a piece of experimental PCB to create a new switchboard. Otherwise some brands have a switch board with a connector you can use to fix it. Just find out the common and 2 switch wires by just connecting 2 wires. The combination when it switches on and of and the combo that brings it in program mode will give the info how to connect it to the switches.
Roelof is offline
Old 09-05-2018, 07:30 AM
the rc guy's Avatar
looks like a on off switch not a dual push button switch.http://www.redcatracing.com/manuals/...10BL50-RTR.pdf
Old 09-05-2018, 09:50 AM
Roelof's Avatar
I see. So with the right 2 wires connected to each other the ESC is on and then you need to plug and unplug the battery
Roelof is offline
Old 02-11-2019, 07:35 AM
1/8 IC Fan's Avatar
Trader Rating: 78 (99%+)
Have you contacted Hobbywing their customer support is ace!
1/8 IC Fan is offline
Old 02-11-2019, 10:08 AM
the rc guy's Avatar
if esc sw has 3 wires then yes its a on/off. with push button . so there will be a shared Neg. and 2 different pos.+.. and yes you can twist the on off wires together to turn esc on.
Old 02-13-2019, 04:01 AM
Regional Moderator
disaster999's Avatar
Got a toggle switch and a press button switch, and replaced the broken switch on the HW ESC and made my own
disaster999 is offline
