Orion R10 esc questions
Ok, I bought an Orion R10 esc here and the seller did not have any information on it. It does not say stock and it does not say pro. It is sliver and has NO numbers on it anywhere. How can I tell if it is a pro, what happens if I put a mod motor on a stock esc will it burn up the motor or esc? Not to worried as it is on my wife's car now with a 17.5 but I would like to know how to tell them apart if it is possible. again it is the silver case, and only says R10 on it. I tried to contact Orion but as in the past they don't respond to emails as their customer service related to my issues has always been non existent. I appreciate any help or information you might be able to provide. Just kinda new to electric and not sure what happens if I put a mod on a stock esc if it works but no punch or if something gets smoked...
The best way to check would be to try to change the running mode settings as they’re different between the R10 and R10 Pro.
The R10 just has two settings, whereas the R10 Pro has seven.
If you don’t have the program box, follow the steps attached.
