Radiolink RC4GS for begginer racing?
#16
More ergonomic - the RC4G isn't uncomfortable (it's light!) but it doesn't have the best grip and isn't adjustable. The Noble has two backstrap sizes, a semi rubberized grip, you can remove the base battery and run it off the 18650 cell that's in the handle to reduce the weight, the trigger and wheel are adjustable, etc.
Build quality - the RadioLink radios won't fall apart on you (or at least mine didn't) but they feel very light and very cheap. They're made out of cheap plastic and will flex/creak if you squeeze the grip. The Noble is largely metal and even the plastic bits are much higher quality. It feels sturdy in the hand. The downside is it is heavier but it isn't too much imo and you can remove the base to make it much lighter.
The RC4G is a great low to mid end radio. The Noble is a high end radio. They both serve their purpose well.
#17
I think the only thing I don't really like on the RC4GS is the expo. I have it cranked up and I still feel like its is really sensitive for small adjustments. If I could change everything, I'd want a thicker soft touch handle (I just need to get some tennis racquet wrap), and I wish the wheel had a higher amount of rotation. I think its 180 lock to lock. It'd be nice to have the option to have 270 and multi point curve editor for the expo. Still that's asking a lot out of a $70 radio. Its still a good starter radio. More than good enough for bashing and learning. Once I'm more consistent on lap times I'll look into a better radio, but who knows I may get bored of RC before that happens.
#18
I have owned 4 different Fly Sky systems over the years and each one of them has disappointed me for a myriad of reasons, but to sum up my disappointment with Fly Sky, they do not stand the test of time and have a tendency to glitch when too many other radio systems are in use. In contrast, Radiolink has never disappointed me at the track.
#19
I would like to know what power source was primarily used when powering the radiolink for those who had one? I used a 2s lipo 20c 2800mah. I'm wondering if that could have been the cause of my radio issues for a less than yr old radio, never dropped, never got wet, always transported in same foam box it came in.
#20
If you want an original (Sanwa RX-482) like what comes with the MT-S tx/rx package... they are $99-ish. Or... Sanwa-compatible receiver thread
#22
#23
I'm glad to hear another without issues. Tbh I was looking to rule out the possible reasons as to why a less than yr old trx had the issues it had. I recently bought a Futaba 3pv to replace the rc4gs I have but upon reading up on both specs it's amazing to see the 4gs has more than the 3pv. Yet I hold my head knowing that the 3pv is $160+ and I bought the 4gs for under $70. So I'm hoping that the 3pv gives me a better experience than the 4gs did, which I truly enjoyed before the issues.
#24
Must be my bad luck as I've had 2 radiolinks, rc4g/rc4gs and now I'm changing to a futaba. The rc4g first issue were the trims never centered, the output to the rx started to become glitchy so I upgraded to the rc4gs. Now with the 4gs with one rx the kit occasionally has a sudden burst of speed if my finger barely touches the trigger. With the other rx and I'm using r6fg v2 receivers, when driving the car would suddenly come to a stop like the battery died then start up again. 🤦♂️ I really loved my RC4Gs as many around me are using futabas, spektrums and sanwas and I felt good knowing I had a cheap radio and could still be competitive, then the issues started and this radio is less than a year old. Not all have experienced same problems but in having to buy a new radio upgrade, and many rxs I'm just really disappointed in radiolink.
