ESC with cw/ccw settings
delete
castle and tekin both have this option. castle link can be used on a smartphone
You don't have to change the motor rotation direction. The motor plate and spur gear need to be bolted to the other side of the transmission housing. You put the 4 gear transmission together incorrectly. I suggest you look at the instructions more carefully when you are working on your car.
actually it was just a massive brain fart. I never even tried it. 4th gear cancels out turning the motor around. Duh.
Originally Posted by n8b
(Post 15275121)
(Post 15275121)
At least you didn't buy a new esc for essentially no reason. I call that a win. |
| All times are GMT -7. It is currently 11:55 PM. |
