Tekin RX8 Gen3 Low BEC voltage >
Old 07-14-2018, 01:35 PM
Default Tekin RX8 Gen3 Low BEC voltage
I've got a Tekin RX8 Gen3 displaying 5.65 volts on the Sanwa M12s telemetry. Same voltage indicated on multimeter with ESC disconnected from receiver. When Hotwire3 App is activated BEC voltage drops to 4.35 and remains till App is terminated the goes back to 5.65. Hotwire3 BEC set to 7.4v. Any experience with this problem would be appreciated.
Losi 8ight-E 4.0
Sanwa M12s
Sanwa RX-472
Reedy 4 cell 6400 70c zappers
Protek 170s servo
Tekin T8 Gen2 1900KV
Larry Clarke is offline
Old 07-14-2018, 01:46 PM
the rc guy's Avatar
I see that a lot with tekin and castle esc old and new that why I always run a ubec or bec..
the rc guy is offline
Old 07-19-2018, 11:21 PM
Team Tekin
Randy_Pike's Avatar
Losi 8ight-E 4.0
Sanwa M12s
Sanwa RX-472
Protek 170s servo
During programming the BEC voltage must come down to certain range. This would be lower because the rest of the items in the car are putting load on the circuit.
Now ESC disconnected from the receiver, I'd ask what kind of multimeter you're using? IF it's slow it maybe averaging quite a bit. The BEC is "switching" which means it is PWM and not all meters will catch both the "hi" and "lo,"
Randy_Pike is offline
