Icharger x6 Mini 30A Discharge >
Like Tree95Likes
Old 09-07-2018, 01:13 PM
  #61
Originally Posted by AndyArdmore View Post
Correct. To use the Discharge+ function on the ICharger, you will need a new resistor bank. You can make your own if you want.
The Discharge+ function on the charger requires a specific resistance to achieve the desired discharge rate. The X6 itself can dissipate up to 30W maximum. To extend this, we need to use external resistors with heatsinks. Assuming that we allow the X6 to dissipate 30W, and the rest will be dissipated by the resistor bank we make, we can use the following formula to calculate the minimum resistance of our bank:
Resistance minimum = (((Vmax * Id) - P) / Id^2 ) , where Vmax is the max battery voltage, Id is the discharge current, and P is the 30W dissipated from the X6.
This results in the following results for:
2S batteries:
10 Amps: 0.54 Ohms, 54 Watts
20 Amps: 0.345 Ohms, 138 Watts
30 Amps: 0.247 Ohms, 222 Watts
1S batteries:
10 Amps: 0.12 Ohms, 12 Watts
20 Amps: 0.135 Ohms, 54 Watts
30 Amps: 0.107 Ohms, 97 Watts
For the desired discharge rate, you will need a resistor bank of the correct value, and rated for the power dissipation. For 30 Amp, 2S discharge, it looks like 4 x 1 Ohm resistors in parallel, each rated for at least 60W, should work. Be sure to attach these resistors to a large heatsink, to dissipate the heat.
Cheers.
Andy - So if I wanted to discharge a 1s LiPo at 20 Amps, I would need 2 x .5 Ohm resistors in parallel, rated at 50W?
Micro_Racer is offline
Old 09-07-2018, 01:32 PM
  #62
yes that's what I'm thinking I'll find out as soon as my .5 ohm resistors get it
Wjones1040 is offline
Old 09-07-2018, 05:05 PM
  #63
No. Please read my post again. For 1S at 20 amps, you would need a total resistance of 0.135 Ohms. You could use 2 x 0.27 Ohm resistors in parallel, rated for at least 25W.
Micro_Racer likes this.
AndyArdmore is offline
Old 09-07-2018, 09:37 PM
  #64
Trader Rating: 31 (100%+)
Originally Posted by Wjones1040 View Post
Yes that's what I'm thinking
so you get 4 of these?
https://www.ebay.com/itm/1-Ohm-100W-...MAAOSwfjRZ5azf
then maybe get a few of these to cool it down?
https://www.ebay.com/itm/5W-10W-High....c100005.m1851
and what type of glue do you use for the heatsink / fan to attached to the resistors ?
Phillip F is online now
Old 09-08-2018, 12:12 PM
  #65
Originally Posted by RLPowerSupplies View Post
or you could just get one of these and call it a day. https://www.rlpower.net/collections/...silver-edition
would you have an adapter plugs so it will work on the X6?
Old 09-08-2018, 06:51 PM
  #66
Hey Will I got the resistors and it worked perfect, thanks for the video and demo, this helped a lot.
mrod is offline
Old 09-08-2018, 11:53 PM
  #67
This is how I did it for now but Im working on a product to make it easy for people.
does it power the fans as well?
Old 09-09-2018, 10:52 AM
  #68
Good deal... Waiting for my .5's to show up for my 1s discharge.😊
Old 09-09-2018, 11:34 AM
  #69
Trader Rating: 242 (100%+)
I just love my GFX!!!
hanulec and RLPowerSupplies like this.
Andy Koback is offline
Old 09-09-2018, 01:45 PM
  #70
me too....
Old 09-11-2018, 06:10 AM
  #71
I have one, it did not work
what size wire rod are you using to connect the resistors?
Old 09-12-2018, 06:42 AM
  #72
Hey wjones1040 where do you get the heatsinks from? Part number if possible please!
TheJudge359 is offline
Old 09-12-2018, 04:02 PM
  #73
ok, i have tried every beta firmware that i can find and tried 3,4,5 1ohm resisters, still can not get this charger to discharge at 30a on a 2cell lipo. what am i doing wrong? can someone please help me out before i throw this thing in the lake
jessesnellen is offline
Old 09-12-2018, 04:23 PM
  #74
Trader Rating: 46 (100%+)
How do you have the resistors wired?
What is the charger showing the discharge current as?
Extra discharge mode is enabled?
biz77 is offline
Old 09-12-2018, 05:12 PM
  #75
extra discharge enabled
shows 3.4amps when discharging
wired in parallel with 5-1ohm (just like all the other discharge banks)
