Icharger x6 Mini 30A Discharge >
Like Tree95Likes
Old 09-04-2018, 09:50 PM
  #46
Trader Rating: 31 (100%+)
I'm just waiting for someone to figure out and sell the 30A discharger .. .before I buy this icharger x6.
Phillip F is offline
Old 09-05-2018, 07:02 AM
  #47
moparSRT's Avatar
Originally Posted by RLPowerSupplies View Post
That is awesome, only thing keeping me from buying the X6 was the lack of discharge ( im not buying a tiny charger to carry a huge and heavy car battery to the track).
Just ordered a X6 and some 1ohm 100w resistors
What will I do with all the extra pit space
moparSRT is offline
Old 09-05-2018, 09:06 AM
  #48
Wildcat1971's Avatar
Trader Rating: 83 (100%+)
Just get the skyrc discharger.....
Wildcat1971 is offline
Old 09-05-2018, 04:16 PM
  #49
R/C Tech Elite Member
JayL's Avatar
could you make a resistor with switches to turn banks on and off, then you could choose 10,20,30a discharge?
JayL is offline
Old 09-05-2018, 09:39 PM
  #50
Default X6 30 amp discharge
Here you go! hope it helps!
Wjones1040 is online now
Old 09-06-2018, 02:06 AM
  #51
https://youtu.be/QrkW0xE7zao
sweet...thank you so much.
https://goo.gl/images/6imyCk
I have this used in my Icharger 308duo. I wonder if this can be used with the X6 and power the fans using the power supply.
Old 09-06-2018, 02:21 AM
  #52
I have one, it did not work
Old 09-06-2018, 04:03 PM
  #53
Default 1s help
Good job!
Thanks!
need help with the 1s 30 amp discharge!
Old 09-06-2018, 06:49 PM
  #54
Thanks!
I tried this with my existing resistor bank by disconecting the resistors and I couldnt get it to go above 2 amps on the charger discharge, the resister bank is the one you were talking about, are the resistors just the wrong ones on that unit or does it have something to do with the fans, or the firmware on the charger, not really sure, can you shed some light on this for me. Also are you the same will Jones that I used to race 10th scale gas with in the midwest series. Mark Rodney.
mrod is offline
Old 09-06-2018, 07:49 PM
  #55
Yes! Yes! Yes! Mark!
to answer your question yes wrong resistors you have to order (1 ohm) 100w, 50w, 25w how many watts you want, but it has to be a 1 ohm resistors.
Old 09-06-2018, 07:52 PM
  #56
Probably you need half the ohms since it's half the voltage.
Wow your right just ordered some 0.5 ohms
Thank you! I'll see if that's the trick
Old 09-06-2018, 10:04 PM
  #57
I thought it was you i recognized your voice in the video, and thought to myself, I know this guy. Thanks for the info. what is the wattage oh the resistors of the bank that doesnt work. I plug that one directly into my battery and it discharges them, but I actually think it is a 40 amp discharge, and that is problably the issue since the x6 only discharges up to 30. I did think that taking some of the resistors off would lower the rate but then it wouldnt go above 2 or 3 amps of discharge. Thanks for posting this it is not easy to understand sometimes and it seem like some of the people didnt want to share simple images of what they did. Not everyone has the technical knowledge of electronics to understand all of the calculations that some of these guys were talking about.
mrod is offline
Old 09-06-2018, 10:47 PM
  #58
so you get 4 of these?
https://www.ebay.com/itm/1-Ohm-100W-...MAAOSwfjRZ5azf
then maybe get a few of these to cool it down?
https://www.ebay.com/itm/5W-10W-High....c100005.m1851
Old 09-06-2018, 11:07 PM
  #59
Do you think why it's not working because the resistors are not 1 ohm each?
Old 09-07-2018, 09:19 AM
  #60
Yes that's what I'm thinking
