Icharger x6 Mini 30A Discharge >
Like Tree90Likes
Old 05-15-2019, 11:48 AM
  #301
Trader Rating: 72 (100%+)
Originally Posted by Jmowgli View Post
Has anyone tried discharging a 1s Lipo at 30amp? I have a discharge bank and it hooked up I believe the right way per the way I see in the RL video. But he is using a 2s Lipo. When itís all hooked up I can only discharge at 3amp.
Yes you can, something isn't correct in your setup.
Chase1472 is offline
Old 05-18-2019, 06:42 PM
  #302
RLPowerSupplies's Avatar
Has anyone tried discharging a 1s Lipo at 30amp? I have a discharge bank and it hooked up I believe the right way per the way I see in the RL video. But he is using a 2s Lipo. When it’s all hooked up I can only discharge at 3amp.
To discharge a 1s at 30 amps you will need a resistor banks with different rated resistors from the 2s lipo discharge bank.
This is an issue with the x6 if you use a variety of S rated batteries. Each s rated battery will need it's own resistor bank and then if you want to discharge a different amps at different times you will need another different rated discharge bank.
RLPowerSupplies is offline
Old 05-19-2019, 03:45 AM
  #303
Trader Rating: 14 (100%+)
Are you able to charge receiver packs through the JST port on this thing? Hobby shop informed me that it was possible, but I searched through the manual and didnt see anything about that.
mushroomed and RsA89 like this.
Double D Donuts is offline
Old 05-19-2019, 03:26 PM
  #304
Super Moderator
Marcos.J's Avatar
Trader Rating: 205 (100%+)
This is an issue with the x6 it you use a variety of S rated batteries. Each s rated battery will need it's own resistor bank and then if you want to discharge a different amps at different times you will need another different rated discharge bank.
i discharge my 1s at 30amps with the same discharge bank that i use for my 2s the only thing is i need to put the balance wire to the positive wire.
Marcos.J is offline
Old 05-19-2019, 03:43 PM
  #305
Super Moderator
Marcos.J's Avatar
Originally Posted by moparSRT View Post
1S 30A discharge is easy on the X6
myself and mopar have basically the same set up for 1s
Marcos.J is offline
Old 05-19-2019, 04:05 PM
  #306
Super Moderator
Marcos.J's Avatar
Little cheesy but it works lol
Marcos.J is offline
