Icharger x6 Mini 30A Discharge >
Like Tree114Likes
Old 06-16-2019, 08:33 PM
  #286
Trader Rating: 14 (100%+)
Double D Donuts is offline
Old 06-17-2019, 04:01 AM
  #287
Super Moderator
Marcos.J's Avatar
Trader Rating: 210 (100%+)
Originally Posted by Double D Donuts View Post
you need these resistors
Amazon Amazon
Marcos.J is offline
Old 06-17-2019, 04:04 AM
  #288
Super Moderator
Marcos.J's Avatar
Originally Posted by Marcos.J View Post
Same here 27 amps or so with 4 1ohm 100w resistors
I must be retarded. Can someone help me out here? I've wired up the resistors per the instruction image. My negative battery goes directly into the negative on the charger. My positive battery goes to a resistor bank wired up into parallel resistors, and then goes into the charger. I'm getting 30w discharge as before.
here is how i did mine
Marcos.J is offline
Old 06-17-2019, 04:06 AM
  #289
Super Moderator
Marcos.J's Avatar
every time
Marcos.J is offline
Old 06-17-2019, 08:37 AM
  #290
Well I traced your wired as best as I could and it's still not going over 4a. I even set the default to 30a since someone else said adjusting it defaulted him back to the stock 4a
Old 06-17-2019, 03:49 PM
  #291
Super Moderator
Marcos.J's Avatar
you need the proper resistors for this charger if not it will not discharge at 30 amps , you cannot use the same resistors as on a 308/406 duos
Marcos.J is offline
Old 06-17-2019, 03:50 PM
  #292
Super Moderator
Marcos.J's Avatar
you have my wiring correct , also you need the newer beta software
Marcos.J is offline
Old 06-17-2019, 03:51 PM
  #293
Super Moderator
Marcos.J's Avatar
Marcos.J is offline
Old 06-17-2019, 03:52 PM
  #294
Super Moderator
Marcos.J's Avatar
and you need to be "not regenerative"
Marcos.J is offline
Old 06-17-2019, 03:53 PM
  #295
I guess I need to RTFM more often. I had to enable Regen mode in the settings. Didn't realize it had that many options dug down in there. Discharging at 28A now!
Marcos.J and mushroomed like this.
Old 06-17-2019, 03:55 PM
  #296
Super Moderator
Marcos.J's Avatar
i posted in pictures my settings but if you got it at 28 you are doing good
1
Marcos.J is offline
Old 06-17-2019, 10:50 PM
  #297
Roelof's Avatar
If you look close, he has the 1 ohm resistors
Roelof is offline
Old 11-03-2019, 06:48 PM
  #298
Default Thanks
I was having a lot of problems getting this to discharge higher then 2 amps untill I seen this and did a lot of poking around.
thanks for posting
Marcos.J likes this.
TeamThibault is offline
Old 11-03-2019, 07:34 PM
  #299
ttr_racer's Avatar
Trader Rating: 43 (100%+)
Has anyone used the Motiv resistor bank and got it to work?
ttr_racer is offline
Old 11-08-2019, 03:06 AM
  #300
Super Moderator
Marcos.J's Avatar
it will not from what i have seen, its a fraction of the cost just to build your own i spent less than $15 to build it
Marcos.J is offline
