Icharger x6 Mini 30A Discharge >
Like Tree114Likes
Old 10-02-2018, 03:29 AM
  #151
Super Moderator
Marcos.J's Avatar
Trader Rating: 210 (100%+)
Originally Posted by matt prigmore View Post
thanks for sharing the links. Much appreciate 👍🏻
np
Marcos.J is offline
Old 10-08-2018, 02:40 PM
  #152
Super Moderator
Marcos.J's Avatar
Marcos.J is offline
Old 10-08-2018, 06:32 PM
  #153
NutDriver's Avatar
Trader Rating: 23 (100%+)
That thing seems pretty expensive to me.
NutDriver is offline
Old 10-09-2018, 03:15 AM
  #154
Super Moderator
Marcos.J's Avatar
it does im happy with my $11.00 (resistors thru amazon) 30 amp resistor bank
Marcos.J is offline
Old 10-10-2018, 06:13 AM
  #155
Totally different concept though with the regenerative discharging on a third channel, and being an nicely designed package that lets you lump all of your charging gear together.
(Not that I still think it's worth it, but the concept to me is super cool. I'd love to see regenerative tech grow)
mtbwrench is offline
Old 10-10-2018, 09:55 AM
  #156
Super Moderator
Marcos.J's Avatar
little pricey thats all
NutDriver likes this.
Marcos.J is offline
Old 10-10-2018, 02:52 PM
  #157
Where did you get a price at? And for which item?
Bubonic-X is offline
Old 10-11-2018, 12:00 PM
  #158
moparSRT's Avatar
Originally Posted by moparSRT View Post
Yeah everything is set properly, and I re-flashed the software, its just a bad charger ... sending it in for replacement today.
Got my replacement X6 today and am very happy to say it all works fine ... I had a bad charger
Marcos.J and NutDriver like this.
moparSRT is offline
Old 10-11-2018, 05:02 PM
  #159
Default Charging and discharging
ok I have eveything hooked up but when i am charging and want to charge a 2s or 1s at 30 amps no go it will only charge at 5amps. What do I have programed wrong please help.
Thanks Chris
Duck999s is offline
Old 10-12-2018, 06:34 AM
  #160
moparSRT's Avatar
Thanks Chris
Is your charge rate set to 30A ?
Is your power supply capable of supplying 30A ?
Are you using the balance plug ?
moparSRT is offline
Old 10-12-2018, 07:02 AM
  #161
Thanks Chris
I'm willing to bet your power supply isn't capable of the 30A charge rate. What wattage is it rated for? Remember: P=VI (Power = Voltage x Current) so to charge a 2S LiPo to full voltage at 30A will require roughly 252 watts of average available power. Perhaps your supply is only rated for 40-ish watts?
Wasn't there also a firmware issue initially, that restricted charge current?
Old 10-12-2018, 07:08 AM
  #162
danny325is's Avatar
deleted
danny325is is offline
Old 10-12-2018, 07:18 AM
  #163
moparSRT's Avatar
Originally Posted by danny325is View Post
30amp charging, What i understand is that you need a 24v input to charge at 30A otherwise your stuck at 25 amps at 12v(if your power supply can push that). I could be wrong I just got my X6 and I am still playing with it.
NO, the x6 will charge at 30A off 12 volts ... you don't need 24V
moparSRT is offline
Old 10-12-2018, 07:53 AM
  #164
Default Charge at 30 or 20 amps
my power supply is a shure speed 60amp power suppy. I have tried at 20amps and 30amps. No go. I have it set at 20amps and it will not go above 4.5amps. I installed the latest software beta 2 no luck. Discharging at 30 amps with resistors no problem
thanks Chris
Duck999s is offline
Old 10-12-2018, 07:55 AM
  #165
Default Power supply
used that same power supply on my 4010 no problems
Duck999s is offline
