Icharger x6 Mini 30A Discharge >
Like Tree97Likes
Old 09-29-2018, 07:37 PM
  #136
moparSRT's Avatar
Originally Posted by RLPowerSupplies View Post
I posted a warning that this would happen with older firmware versions and the wrong ohm rated resistors. ( post # 39 on this thread )
Dont feel bad, I blew 3 power supplies learning this.
Starting to feel like I have a bad charger, got a code this time, reinstalled the software and tried again ... another power supply went up in smoke At this point I could have just bought a 308DUO
Checked the resistance of 4 resistors ... 0.240ohms, 5 resistors comes in at 0.197ohms. Find it strange the charger works fine on 4 resistors but burn power supplies with 5 ... again thinking I got a bad charger
moparSRT is offline
Old 09-29-2018, 11:28 PM
  #137
Why are you trying to use 5 resistors when 4 should be enough, if you have the correct resistors.
mrod is offline
Old 09-29-2018, 11:30 PM
  #138
Trader Rating: 31 (100%+)
Originally Posted by Marcos.J View Post
Well I got it to discharge at 29.7-29.9amps so thatís pretty close to 30 amps . Cost me about $9 worth of resistors from amazon and always 1day shipping
how about sharing it to us here where you bought these resistors (links)and how you build it and how you connected it to the x6....a lot of us here would really appreciate it.
Phillip F is offline
Old 09-30-2018, 12:01 AM
  #139
my bad, i do have five on mine, sorry for the mistake, but check your resistors and your connections just to make sure you are doing it correctly.
mrod is offline
Old 09-30-2018, 12:24 AM
  #140
R/C Tech Elite Member
Marcos.J's Avatar
Trader Rating: 205 (100%+)
Just look on amazon for 1ohm 100watts resistors simple you need 5 of them . And the new 204 software
Marcos.J is offline
Old 09-30-2018, 09:29 AM
  #141
All the information to make this work is posted in this thread. Why is it so difficult for you to put in a little effort reading through this thread and then figuring it out?
I don't mean to sound like a jerk but some people need to take a little initiative.
because I am not familiar with electronics. All I know is to solder wires to a motor.... which I recently learned.. Why do people here assume that everyone in this hobby knows how to work with stuff that requires more knowledge in machining and electronics? Lol
Old 10-01-2018, 04:54 AM
  #142
moparSRT's Avatar
​​​​​​read and follow pg 17 and 34 here
https://www.progressiverc.com/media/...6%20Manual.pdf
you want regen mode off and extra discharge enabled
Although the pictures you posted earlier look like you have the settings correct already.
Have you tried reflashing the firmware?
Yeah everything is set properly, and I re-flashed the software, its just a bad charger ... sending it in for replacement today.
Marcos.J likes this.
moparSRT is offline
Old 10-01-2018, 05:03 AM
  #143
moparSRT's Avatar
Originally Posted by NutDriver View Post
With all of the talk of reaching a 30A discharge rate with the x6 and the required hardware and wiring, I have to ask what discharge rate is possible out-of-the-box?
around 4A
NutDriver likes this.
moparSRT is offline
Old 10-01-2018, 06:11 AM
  #144
Marcos.J's Avatar
not that much hardware needed you probably spend less than $20 in parts and about 25-30 minutes to put it together. the main thing is to load the new software and the proper charger settings . I spent about $13 including 1day shipping for the resistors (I already had ha extra cooling fan)
Marcos.J is offline
Old 10-01-2018, 09:46 AM
  #145
JayL's Avatar
What does that 'AD watchdog error' mean?
I got it once while it was just sitting there
JayL is offline
Old 10-01-2018, 02:32 PM
  #146
Default 2.0.4 firmware
would someone point me in the right direction to get a link to download v2.0.4 firmware.
i have downloaded the latest software from jun-si via the soft link on my pc.
so far Iíve been able to discharge up to 30 amps with a discharge extender the I made and have came across any problems.
matt prigmore is offline
Old 10-01-2018, 03:48 PM
  #147
Marcos.J's Avatar
https://m.facebook.com/story.php?sto...69473393148894
Marcos.J is offline
Old 10-01-2018, 05:53 PM
  #148
cnk
Or go here instead and get it direct from the source, i.e. Junsi: https://www.rcgroups.com/forums/show...&postcount=237
cnk is offline
Old 10-01-2018, 06:01 PM
  #149
Marcos.J's Avatar
wow cool thanks never new that
Marcos.J is offline
Old 10-01-2018, 11:14 PM
  #150
Default 2.0.4
thanks for sharing the links. Much appreciate 👍🏻
