-   -   Sanwa M12 (https://www.rctech.net/forum/radio-electronics/1017768-sanwa-m12.html)
ccccam 05-10-2018 02:17 PM
Sanwa M12
Hi All,
I have a Sanwa M12, in brand new condition, all works well except it's range is limited to approx 40 meters, once i get out of this rand the 2nd red LED light comes on and shut off all contact to the receiver until you get back in range. can any one please recommend where i can take it or post it to have it looked at.
Or may know how to fix it.
Another option i am considering if anyone has one they no longer use (broken) interested in purchasing one for parts so i can see if I can get part to fix my controller.
Any help would be greatly appreciated
Thank you
​​​​​​​Chris
Riverbluff 05-11-2018 10:06 AM
Originally Posted by ccccam (Post 15225457)
Hi All,
Thank you
Chris
are you sure it isn't the receiver causing the problem? I would consider that before the transmitter. Try rebinding the TX and RX and make sure your antenna on the RX is ok, and routed properly.
ccccam 05-15-2018 04:24 AM
Thank you for your reply Riverbluff,
That is what i first thought, i tried 3 different receiver , with all three had the same problem, even bought a new receiver that has internal antenna, still same problem. I also tried all three receivers with another transmitter while in the same buggy, no problem there.
Thank you
Chris
